rear brakes wear first???
Old Apr 20, 2005 | 02:20 AM
holdenontoit's Avatar
holdenontoit
with the majority of the MINI's weight distributed over the front wheels, why should my rear brakes have worn out well before my fronts? (they did)
Old Apr 20, 2005 | 05:16 AM
RedBaronF2001's Avatar
RedBaronF2001
Did you purchase the MINI new? I suspect a problem if so.
Old Apr 20, 2005 | 05:23 AM
holdenontoit
yep, june build , 2002 ,MCS , just rolled 50,000.
Old Apr 20, 2005 | 05:55 AM
savage65's Avatar
savage65
I'm guessing that you have DSC on your MINI. The DSC module can cause the rear wheels to have their brakes activated, hence they can get used more that the front ones.
I wore out my pads on the rear at 28,000 miles; front pads are still fine even though I have done four autocross events and drive pretty hard as a rule too.
There is nothing wrong with your car.
Old Apr 20, 2005 | 06:03 AM
holdenontoit
I think you nailed it!
good info, and yes ,I do have DSC .The resident car Guru here at work said the exact same thing.I guess with my mileage, I don't have too much to complain about, but I'm going up Mt. Washington in a couple of months, so I'm going to treat this as a good excuse to upgrade the whole system..........what to buy, what to buy.................
Old Apr 20, 2005 | 06:05 AM
tsprayfhs's Avatar
tsprayfhs
Yup. It is quite common for the rear brakes to go out first. More that wieght enter into the problem. Brake biase, pad compound, driving style, etc. Many dealers are reporting the rears going first. Mine were out at 32,000 and the fronts soon after. The same for many people in this area. And bye-the-bye whoever came up with this brake pad should be flogged daily until the end of time.
Motor on
Old Apr 20, 2005 | 07:10 AM
warchieft2k's Avatar
warchieft2k
hey, i had that same issue... my rear pad were gone at about 15k miles and i got 24k now and im replacing the front ones now.
im almost sure it is due to the DSC... remember unless you take it off its workin all the time so it keeps using your breaks special i guess the rear brakes.
Old Apr 20, 2005 | 04:01 PM
MrV's Avatar
MrV
The finance guy at the dealership where I bought my car told me that his mechanic was reporting the same thing. He was also theorizing that the DSC was the culprit.
Old Apr 20, 2005 | 04:13 PM
sfjames2's Avatar
sfjames2
Why are you guys demanding all this help from the DSC??
57,000 miles on me originals still. They are ALMOST due.
Old Apr 20, 2005 | 07:41 PM
warchieft2k
see i just forget to turn the damm thing off sometimes and then i lunch hard or take a turn and there it goes....
now only does it slow you down as well as take the fun out the turn or lunch but it eats up your the rear brake pads
Old Apr 21, 2005 | 05:19 AM
tsprayfhs's Avatar
tsprayfhs
The DSC thing has nothing to do with my car,Pepper. Don't have it, don't want it. But Pepper's rears were still the first to go. 30,000+ on the pads living in the mountains and a couple of track days is not bad for the pads. And I don't really care if the rears went first. What difference does it make? Now the dusting problem is another story for another thread.
Motor On
Old Apr 21, 2005 | 07:09 AM
toddtce's Avatar
toddtce
I'd have to point the finger at compound more than stability control. Sure, more pressure more often means more wear, but you could get the same results I believe out of a longer life pad.
*!But then you could put larger rotors on the rear- they don't have to work as hard to get the same torque value! (ok, shamless plug)
Old Apr 21, 2005 | 08:14 PM
Ryephile's Avatar
Ryephile
Model Year 2002 MINI's have a bad habit of dragging the rear brakes (i.e. binding the calipers), even with the DSC off. The brake pad compound, or having the DSC on, has nothing to do with it
Toolman
Jan 20, 2016 06:50 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
jpgwinn24
Tires, Wheels, & Brakes
Aug 23, 2015 02:53 PM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
