superleggara or not so super?
Old Apr 19, 2005 | 10:44 AM
MariosMCS's Avatar
MariosMCS
Bottom line...Will OZ SuperLeggara 17"'s(37mm offset) w 205/45/17 Tires rub once my M7 springs are installed, I've found conflicting info on different threads.
Old Apr 19, 2005 | 05:16 PM
MariosMCS's Avatar
MariosMCS
BTW my car is an 2005 MCS w/ adj. camber if that makes a difference.
Old Apr 19, 2005 | 07:03 PM
JeffS's Avatar
JeffS
I'm running 17" Superleggera's with 215/45/17's w/H&R springs and a large rear swaybar.
I have no rubbing issues currently. I'm running stock rear arms though, and I think there's a chance I might if I were to zero the camber out in the rear.
You're proposing narrower tires which is good, but softer springs which isn't. If I had to guess I'd say you'll be ok. I know my setup isn't really comparable, but maybe it'll help.
Old Apr 20, 2005 | 11:18 AM
JeffS's Avatar
JeffS
Sorry, I was wrong. I realized today that my tires are 40 series, not 45.
Old Apr 21, 2005 | 05:54 AM
Alex@tirerack's Avatar
Alex@tirerack
205/40 is very short in diameter, and low in load capacity. I doubt it will rub, but its TOO short for the vehicle. 205/45 or 215/45
Alex
Old Apr 21, 2005 | 04:50 PM
JeffS's Avatar
JeffS
Maybe, but we're talking about 215, not 205.
I would argue, however, that because of the tall gearing of the MCS, a smaller diameter can be a good thing.
Old Apr 21, 2005 | 07:55 PM
djafactor's Avatar
djafactor
I need help too, I'm running 17" OZ Superleggras with Yok ES100s 215/45/17 on H-Sport Springs ('05 MCS). Having running problems at the rear (even after a fender liner trim). What should I go for? 215/40/17 or 205/45/17. There is not much choice in the 205/45/17, but if the ES100s will fit for sure then i'll go for them again (no-way will I run Pradas).
any help is greatly appreciated.
thanks
Amit
Old Apr 21, 2005 | 07:56 PM
djafactor's Avatar
djafactor
thanks
Amit
Old Apr 21, 2005 | 08:12 PM
Ryephile's Avatar
Ryephile
It depends on the shape of the tire. Yoko ES100's, for example, have a very square shoulder and are more likely to rub than the same size Yoko Parada Spec-2 (which has a rounder shoulder, and btw is a stickier tire in the dry, but not the wet) Overall, you'll be ok - you may have some rubbing but not a major issue with the 205/45-17 size. Also note that if you start camber correcting for lowering the car, you'll increase rubbing in the back.
Cheers,
Ryan
Old Apr 21, 2005 | 08:15 PM
CustomAV's Avatar
CustomAV
I hate to hijack but can you guys w/ the suppers post pics of your rides? I have been curoius to see what the supers look like on the MINI.
Chris
Old Apr 22, 2005 | 05:35 AM
djafactor's Avatar
djafactor
Here is my car:
Old Apr 22, 2005 | 05:56 AM
djafactor's Avatar
djafactor
JeffS: What tire brand are you running in the 215/40/17?
thanks
Amit
Old Apr 22, 2005 | 08:54 AM
VoiD's Avatar
VoiD
I'll be mounting 17" superleggeras with 215/40 Falken RT615s on Monday so I'll post results if there is any chance of rubbing.
Old Apr 24, 2005 | 06:40 PM
MariosMCS's Avatar
MariosMCS
I went with 18"s!
Thanks for the feedback guys.
Fedex lost one of my wheels for three days. So with the extra time to think and research, I sent back the 17"s and ordered 18"s. It seems that with the 42 offset of the 18"s, there will likely be less problems..not to mention more bling. I will post pics and results of the decision later this week. I hope I made the right choice.
Old Apr 24, 2005 | 07:45 PM
JeffS's Avatar
JeffS
thanks
Amit
Kumho MX
Old Apr 25, 2005 | 07:22 AM
Ryephile's Avatar
Ryephile
YAY for 18's!
bctf1
Jan 2, 2016 04:02 PM
semibreve42
Oct 2, 2015 09:06 AM
SneedSpeed
Oct 1, 2015 03:01 AM
fkrowland
Sep 30, 2015 10:30 AM
dgamblin
Sep 29, 2015 10:06 AM
