front end vibration after replacing runflats
Old Apr 18, 2005 | 08:53 PM
dconte007's Avatar
dconte007
Hey guys,
I need your help. On Saturday I flated on the freeway and yes i was traveling about 80 mph whenthe tire failed. Front Right. I slowed and then pulled over to confirm, but I needed to drive 15 miles to the tire shop, but I was going very slow but the front end felt like it was takng a pounding.
Well I decided to replace all the tires and wheels, I moved up to 215s and then when I drove off there was a very noticeable vibration and it feels worst on the right side.
I had the tires rechecked for balance and that helped slightly.
Could I have trashed the alignment? done damage someplace else? need your thoughts on this.
You can really feel and see the vibration in the steering wheel, speeds as slow as 40 all the way to 70 but after 70 it goes away. Help please.
Old Apr 18, 2005 | 09:14 PM
dkstone's Avatar
dkstone
You may have bent a rim ever so slightly and that will cause that problem, had the same thing happen to one of my R90s. So I replaced them with kosei K1 TS
Old Apr 19, 2005 | 04:19 AM
petecrosby's Avatar
petecrosby
He said he replaced the wheels also.
In my opinion, either you have a balancing issue or else you did not get hubcentric rings with the wheels. A last possibility is that you did get hubcentric rings but they were the plastic type and they aren't doing the job, in which case you should get a set of metal rings.
Hope this helps.
Old Apr 19, 2005 | 05:37 AM
Alex@tirerack's Avatar
Alex@tirerack
this is my guess also!
Alex
Old Apr 20, 2005 | 09:18 AM
dconte007's Avatar
dconte007
Problem solved
It was the hubcentric rings,
Thanks guys, problem solved
Old Apr 20, 2005 | 05:42 PM
petecrosby's Avatar
petecrosby
Good deal.
Old Apr 21, 2005 | 06:37 AM
camminich's Avatar
camminich
Originally Posted by dconte007
hubcentric rings,
Ok, stupid question, but what they heck is that ?
silence2-38554
Nov 12, 2015 09:39 AM
maestro39
Oct 27, 2015 02:38 PM
Colt45Magnus
Sep 7, 2015 10:47 PM
FatherG
11
Aug 7, 2015 07:49 PM
