Cheap decent/good tires :)
Old Apr 15, 2005 | 02:50 PM
kyle00's Avatar
kyle00
I need new tires because my stupid runflats are getting really worn down, I dont need anything fancy and would like something that is pretty cheap. I want them to last long and I am not worried about crazy performance or anyhting, just every day driving. If you guys could help me out that would be great. I forget the size, but I want the tires to be a little bit wider but still fit on my rims... they are the same size as the stock sport package ones, I think its 17x7???
Old Apr 15, 2005 | 03:05 PM
binkysmini's Avatar
binkysmini
I have been pretty happy so far with my Falken Ziex 512s. Put them on a couple of months ago. Now that I looked at Edge Racing's site for the plus size (205/45/15 stock-215/40/17 is +1), I find that if I had gone plus size I would have saved about $14 each. Doh!
Old Apr 15, 2005 | 03:07 PM
meanboy's Avatar
meanboy
if you don't mind the stock size
http://www.edgeracing.com/tire/936/
$73 a tire
One size up..
http://www.edgeracing.com/tires/2154517/
A few in the $70 range including the Falken 512.
Old Apr 15, 2005 | 03:08 PM
DVLMINI's Avatar
DVLMINI
I'm having the same dilemma and spending entirely too much time on it.
I'm leaning toward the Bridgestone Fuzion ZRI. See eBay $290 for 4 although the shipping is high.
Old Apr 15, 2005 | 03:23 PM
kyle00's Avatar
kyle00
Thanks for the quick replies guys, for the "size up" those are just alittle wider right? They will still fit correct?
Old Apr 15, 2005 | 03:27 PM
KiLO's Avatar
KiLO
Dang man, the Falken Ziex 512's are 60 bucks each in the 205/40/17 size at edgeracing.com... That's pretty darn good.
Old Apr 15, 2005 | 03:39 PM
meanboy's Avatar
meanboy
I am running 215/45/17 on 17x7 SSR GT1..no problems. Whats you offset? They did scape once and awhile with the Kosei K1 TS.
Old Apr 15, 2005 | 06:35 PM
kyle00's Avatar
kyle00
Sorry I am very tire illiterate, is offset the bolt pattern or something? I think its 4x100??
Old Apr 15, 2005 | 06:48 PM
Rick-Anderson's Avatar
Rick-Anderson
The best prices I have found for quality tires in Orange County is at Super Autobacs in Stanton/Garden Grove. Example: Toyo Proxes4 215/45/17 are $94 each plus $10 mounting & balancing. They have much cheaper tires, though. This place is amazing - like a giant candy store for high end go-fast goodies.
http://www.autobacsusa.com/store.html
If you have the stock wheels and springs, 215/45/17 should not rub. Keep in mind that the 215 is the width in mm, and 45 is the aspect ratio - not the actual sidewall measurement. What that means is that 45 represents 45% of the width so on a 215 wide tire "45" has a 96.75mm sidewall while "45" is a 92.25mm sidewall on a 205, 87.75mm on a 195, etc. These are rough sizes and may vary depending on the tire.
You can compare sizes on this website: http://www.1010tires.com/TireSizeCal...?action=submit
Old Apr 15, 2005 | 06:52 PM
Rick-Anderson
The offset is the difference between the exact middle of the width of the wheel and the face in which the wheel makes contact with the mounting surface or hub.
Waszak
Oct 21, 2017 05:55 PM
dube53
R58 :: Coupé Talk (2012+)
Sep 11, 2015 09:30 AM
Anakist
Australia
Sep 8, 2015 03:32 AM
Ntety
Sep 2, 2015 08:39 PM
