Navigation & Audio Theory-But will it work?
Old Mar 1, 2005 | 01:01 PM
CARdiac's Avatar
CARdiac
I am told the iPOD can't be used with the Sirius (w/navigation) because they connect to the same spot.....Would it be possible to put a switch in to allow you to connect both and switch b/w the two?
Old Mar 1, 2005 | 02:23 PM
LeeL's Avatar
LeeL
Might work if you turned the radio off before the switch.
I think I read either here or MINI2 that someone got both working by basically making one custom harness for both by taking them apart and installing all the pins into one connector. Seems that while they use the same physical connector, there are different pins, you just can't normally plug into all of them at the same time. I might be totally wrong about it but I would at least pull teh radio and check the pinouts on the back for everthing.
Old Mar 1, 2005 | 04:09 PM
mbabischkin's Avatar
mbabischkin
That's a distinct possibility... Do you have HK? The HU for the HK actually has two connectors in the back, so you can have the NAV and the iPod connector
Old Mar 1, 2005 | 05:57 PM
CARdiac's Avatar
CARdiac
I have the Nav and the Ipod... I know you can have the Nav and the Sirius or the Nav and the Ipod, but not the Nav+Ipod+Sirius
Old Mar 1, 2005 | 06:01 PM
mbabischkin
But do you have HK?
Compare the Nav Ipod and Sirius connectors... If they don't share any pins on the connector it shouldn't be a problem to pop open the connector and insert the pins in the vacant slots if you don't have HK and thereby only have a single input plug on the back of the radio.
Old Mar 1, 2005 | 06:25 PM
CARdiac's Avatar
CARdiac
No HK....
I just got the car this past Sat, my wife would have a stroke if I opened the dash so soon
I was asking so if it can be done I can plan it out in advance...the less she knows, the longer I live
ebowling
90
Aug 4, 2019 09:15 AM
triple5soul
21
Jul 29, 2016 04:27 AM
Getrieben
Aug 15, 2015 09:09 PM
minipopkart
Aug 13, 2015 05:22 AM
joelcseymour
Aug 7, 2015 12:43 PM
