New Bremmen Parts & Back in Stock! New JCW Parts!
ECS Tuning
Back in Stock! Save those expensive factory headlights!! Headlight Lens Replacements - R55-R59/R60/R61/F55-F57
Have faded factory headlights and want to keep those lights looking new? Replace the lens.
Refinishing the surface of the old lens only last less then a year requiring year after year buffing and it does not get them back to 100% new.
Use these lenses that are based off the original design. Ceramic coat them for additional protection!
You will need to heat up the older housing and clean out the butyl black glue. When installing the new lens you will need to heat the housing up again with glue strip installed (after cleaning out the old glue in the housing) and "Bake" the new glue to hold the lens. If you cannot do this process most shops can perform this fix for you with our parts!
For your MINI Cooper 2007+
R55-R56-R57-R58-R59 MINI Cooper /S/JCW 2007-2015 Gen 2 (Xenon Only)
R60 Countryman / R61 Paceman /S/ S ALL4 /JCW 2012-2016 Gen 2 (Xenon Only)
F55-F56-F57 MINI Cooper /S/JCW 2014+ Gen 3 (Halogen and LED)
R55-R56-R57-R58-R59 MINI Cooper /S/JCW 2007-2015 Gen 2 (Factory Xenon Only)
"Click HERE for the R55-R56-R57-R58-R59 MINI Cooper /S/JCW 2007-2015 Gen 2 (Factory Xenon Only)"
R60 Countryman / R61 Paceman /S/ S ALL4 /JCW 2012-2016 Gen 2 (Factory Xenon Only)
"Click HERE for the R60 Countryman / R61 Paceman /S/ S ALL4 /JCW 2012-2016 Gen 2 (Factory Xenon Only)"
F55-F56-F57 MINI Cooper /S/JCW 2014+ Gen 3 (Factory Halogen and LED)
"Click HERE for the F55-F56-F57 MINI Cooper /S/JCW 2014+ Gen 3 (Factory Halogen and LED)"
Resealing Glue - Butyl Glue - Black
"Click HERE for Butyl Glue"
Ceramic Coating Kit
"Ceramic Coating Kit"
NEW F60 LCI Headlights!
*Designed for MINIs without factory LED headlights.
Plug-and-play.
**factory halogen headlights do not have headlight washers**.
"Click HERE for the F60 Ziza LED Headlight upgrade"
New R60 Countryman/R61 MINI Paceman JCW Style Grilles!
Fits Cooper S, S All4, and JCW
"Click HERE for the R60 MINI Countryman/ R61 MINI Paceman"
New F66+ JCW Parts Added to the site!
"Click HERE for the for the New F66 MINI Cooper S JCW Parts"
Ceramic Coating Kit
Sequential Projector LED DRL Headlights F60 LCI Style For F60 - Pair
These headlights are designed to resemble the later Gen 3 F60 LCI+ MINI OEM LED Projector headlights, but are for the F60 MINI Cooper Models. Featuring high impact plastic lenses with black housing, these lights use an LED DRL and black exterior LCI+ design.*Designed for MINIs without factory LED headlights.
Plug-and-play.
Jan 19, 2023 12:23 PM
Feb 10, 2017 01:52 PM
Feb 10, 2017 01:49 PM
