JCW Replace while Tranny out
Old Apr 29, 2026 | 08:07 AM
shakham's Avatar
shakham
Wondering what I should get replaced while tranny is out...
This is 2017 F54 JCW Manual..
I lost 6th gear while cruising on the highway, and it looks like my tranny is toast :(. Dunno how that happened.
Here is a list I have so far as what to replace:
1) clutch disk + pressure plate + throwout bearing - $300-$700
2) slave cylinder - $100-$250
3) rear main seal - $30-$80
4) transmission input shaft seal - $20-$50 (only if used tranny)
5) transmission mount
Any thoughts or anything else to add?
Old Apr 29, 2026 | 06:07 PM
RudeJoe's Avatar
RudeJoe
No need to replace the slave cylinder unless something is wrong with it.
Old Apr 30, 2026 | 08:11 AM
cristo's Avatar
cristo
Alliance Member
While the trans is out, how
about cracking the case to
put in a Quaife or Wavetrac.
Old Apr 30, 2026 | 09:00 AM
shakham's Avatar
shakham
I read that there isn't much of a benefit for an AWD. Is that incorrect?
Honestly..I'm not well versed on adding an LSD.
Old Apr 30, 2026 | 09:17 AM
shakham's Avatar
shakham
Any opinions on putting a lighter flywheel?
Any clutch reocmmendations?
I was thinking..
ACT Heavy Duty Performance Street Rigid Clutch Kit
https://www.ecstuning.com/b-act-part...bm19-hdsd~ach/
Old Apr 30, 2026 | 09:36 AM
joe_bfstplk's Avatar
joe_bfstplk
I was thinking..
This is how we do it.....
Not a 3rd gen owner, but I like my ClutchMasters aluminium flywheel and FX350 clutch on my R53. Maybe they make one for your car, too....
Old Apr 30, 2026 | 10:42 AM
shakham's Avatar
shakham
I assume that's the 14lb flywheel. What do you like about the lighter flywheel?
I would think with the rev dropping during shifts, it may take you out of the power band?
Old May 1, 2026 | 01:01 PM
joe_bfstplk
Revs quicker, FX350 grabs well enough for my old BVH/cam without slipping and still engages like a stock clutch. Miss the BVH. Lost it with the old engine. New factory crate engine has stock head for now....
Old May 1, 2026 | 01:13 PM
shakham's Avatar
shakham
I have been doing more research, and found that the ACT doesn't have the holding power I need.
It's between the FX300 and FX350. I'm leaning towards the FX300 mainly for driveability, and that I don't think I'll ever need the additional clamping force. The car is currently stage 1, and at most I'll go stage 2, even that is undecided.
It's a bit odd that BMW/Mini moved the springs from the clutch into the flywheel (hence dual mass setup). I read that their setup helps with smoother shifts.
Did you notice any change in shifting with the new setup?
BTW...does anybody know with the tranny out, does changing the down pipe become any easier?
Old May 2, 2026 | 09:38 AM
joe_bfstplk
The FX350 shifts just as amooth as the factory clutch. Not grabby or finicky at all. If given the choice, even if I didn't think the extra clamping force was needed, I would still pick the 350, as it leaves the door open for making more power and not having to circle back and upgrade the clutch again....
Old May 2, 2026 | 06:30 PM
shakham's Avatar
shakham
I'm reading that it's best to leave the RMS (Rear Main Seal) alone unless it's leaking. There is a risk of a leak being caused by the install.
My first question...has anybody replaced their RMS in the F-series Mini?
Has anybody had leaks after replacement?
soundnav
R55 :: Clubman Talk (2008+)
Jul 5, 2021 07:12 AM
Staxtis
Mar 9, 2021 01:17 AM
