R50/53 Power steering line parts quality
Old Apr 8, 2026 | 10:07 AM
fastalan's Avatar
fastalan
I will be replacing the power steering lines (both up and down tubes) and most likely the pressure hoses on the steering rack. How are your lucks at buying non dealer parts for these repairs? It's for my 2006 R50 with rather low mileage (mid 90000 km); however, the car is simply too old and the ps fluid suffered a major leak after the winter. I am in Vancouver BC so I can buy parts from my local Mini dealers or have parts ships in from the US.
Old Apr 8, 2026 | 10:14 AM
LukasH's Avatar
LukasH
I replaced all lines with new ones from Meyle two years ago and they still work fine.
The only issue I had were getting the two banjo bolts on the pump at the transmission side to stop leak. I had bought new crushwashers from the dealer and torqued them to Haynes spec (40nm if I remember correctly) but I had to go back twice to tighen them way harder to make them stop leaking.
Old Apr 8, 2026 | 12:23 PM
Big thing is the install. Replace those washers. I did my lines with aftermarket and its been fine. The Genuine MINI ones did swell a bit over time and leaked on the original lines, they only last so long.
Make sure you clean the PS fan out and turn it with you finger, the fan tends to rust on the inside and stick. Mine started to hang up and was not smooth so i just replaced it with new SPAL unit.
DIY https://www.northamericanmotoring.co...-blow-out.html
Old Apr 8, 2026 | 01:26 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Replaced both my PS reservoir hoses with 'no-name' eBay back in 2017 when my original ones began to leak/fail. I used the supplied crush washers and worm gear clamps that came with the hoses.
So far in 9years they haven't leaked.
I'll most likely have to perform another PS fluid flush/change soon.
Not sure where I'll source new hoses when the time comes.
Old Apr 8, 2026 | 02:29 PM
noodlesandsam's Avatar
noodlesandsam
My only hint - I had to replace the pump. I broke one O ring of the high pressure line - the rubber one. I warmed
up the second one, and it was good. Yes, replace all metal o rings.
Old Apr 8, 2026 | 05:38 PM
fastalan's Avatar
fastalan
Thanks everyone for the head ups. Look like it's best to buy a complete kit so time to place the order and start getting my hands dirty.
Old Apr 9, 2026 | 07:55 AM
ghostwrench's Avatar
ghostwrench
I bought all my lines from FCP Euro when I did mine a few years ago. No problems at all.
Old Apr 9, 2026 | 04:48 PM
doherty80's Avatar
doherty80
I used the ECS repair kit....have gone a few hundred miles and have been pretty happy. I think for upper lines to reservoir was like 75.00 . Can't complain.
Old Apr 11, 2026 | 01:23 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Regardless of which lines/hoses you choose...
Worst job EVER having to replace!
​​​​​​I extend you my sympathy and best wishes.
Old Apr 11, 2026 | 03:41 PM
ssoliman's Avatar
ssoliman
Much easier job with the subframe out 🙏
Old Apr 11, 2026 | 03:55 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Yes/agree!
But next time I'm renting a lift
Old Apr 12, 2026 | 08:23 PM
deepgrey's Avatar
deepgrey
It’s been a while since I last changed mine, but I don’t recall it being that bad. I did pull the front wheels and inner fenders so that I could reach in from the side though.
Old Apr 13, 2026 | 02:07 PM
Here2Go's Avatar
Here2Go
NAM Community Team
My original ones blew so badly - It was a total mess down there. Clean-up was a nightmare.
Old Apr 15, 2026 | 07:07 AM
deepgrey's Avatar
deepgrey
Ah, that makes sense. I’ve always changed mine before they got too bad.
MiniManTim
Aug 28, 2014 01:33 PM
gsxspooling
Jul 10, 2010 04:08 AM
four_ari
Mar 10, 2010 05:55 PM
colorof$
Aug 5, 2003 01:51 PM
