R50/53 Right front axle for 03 R53
Old Mar 16, 2026 | 08:15 AM
BMH94's Avatar
BMH94
Hey everyone
I need a new right front axle for my r53. It's leaking axle fluid and boot is torn. Car still drives. But I don't want to risk it. My car has a quaife lsd. Would any 03 r53 axle work, or do I need a specific one with the quaife lsd?
Old Mar 16, 2026 | 10:01 AM
GLEX's Avatar
GLEX
Hopefully others will chime in, but I believe the consensus is to avoid aftermarket axles (better off rebuilding a genuine MINI axle) and that you shouldn't need a different axle to accommodate a Quaife LSD.
Old Mar 16, 2026 | 01:25 PM
Here2Go's Avatar
Here2Go
NAM Community Team
I don't know the answer with regards to compatibility with your Quaife Lsd.
Last time I spoke with@WayMotorWorks of Atlanta,Ga - They can rebuild or have rebuilt OEM axles. I imagine they can help and answer your question
Old Mar 16, 2026 | 02:14 PM
ssoliman's Avatar
ssoliman
+1 rebuild
they have kits on the regular parts sites
once you get the cv joints cleaned you can see the condition clearly / easily
Old Mar 16, 2026 | 07:29 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If you have a genuine MINI original axle then rebuild it. The aftermarkets are more junk than good, as I've seen more problems with aftermarket than them actually fitting right. Also the aftermarkets don't hold the power like the originals. We rebuild them all the time as MINI discontinued the originals.
Old Mar 18, 2026 | 02:37 PM
BMH94's Avatar
BMH94
I'll check to see if it's oem, or not. Thank you, all!
cooper48
Jun 17, 2024 11:41 AM
doomi
15
Apr 8, 2019 05:56 AM
yyj3869
Apr 12, 2018 03:34 PM
fancy sauce
Apr 3, 2017 01:39 PM
