R58 Electrical Problems
Old Mar 12, 2026 | 08:14 PM
sully325's Avatar
sully325
Electrical Problems
Hi everyone,
Ok, so I have an 2012 Cooper Coupe R58 with close to 200k mi on the chassis. I recently changed the brakes on all 4 corners and about a week later I am getting DSC failed warning on the display. When checked with a Foxwell scanner, I'm getting multiple (9) DSC codes including yaw sensor fault, longitudinal accelerator sensor fault, multiple DSC "no DSC message", and multiple (4) CAS codes as well, CAS Control Unit fault, CAS 1,2,3 terminal 15 outlet faults ... The car has refused to start a couple of times when start button is iniitally pushed but then will start if pushed again - The battery is new and coded to the car, the key fob is new and was coded by a dealer, the charging system is showing 12.3v cold and goes immediately to 14.3v after start, the ground cables are both intact and I have cleaned the contact points ensuring they are bare metal. The FRM was rebuilt and recoded about 6 mos ago. There was no water intrusion or corrosion in the footwell or floor at the time. Has anyone experienced all of these problems concurrently? ANY ideas of where to go from here will be appreciated. I gotta get this fixed, it's driving me nuts!
Old Mar 13, 2026 | 03:47 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Did you knock or break one of the speed sensors during the service?
Old Mar 13, 2026 | 08:20 AM
sully325's Avatar
sully325
Will be double checking all 4 later today.
Old Mar 13, 2026 | 11:25 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Would help if you post all of the fault codes.
Old Mar 13, 2026 | 03:26 PM
sully325's Avatar
sully325
Just drove and live tested the speed sensors - all are reading accurately and for a decent distance
Old Mar 13, 2026 | 03:28 PM
sully325's Avatar
sully325
CAS and DSC codes
Old Mar 13, 2026 | 04:06 PM
Maybe, maybe not
Community Builder
That's a complex set of fault codes, all of which could potentially be caused by an intermittently failing CAS module.
However, before deciding on any direction to take, first clear all of the fault codes and then turn ON the ignition key without starting the engine to check which codes, if any, return. Post all codes that return after clearing the current ones.
Old Mar 13, 2026 | 04:15 PM
sully325's Avatar
sully325
Yes, have done this many times over the past few days ... same codes reappear .... I'm leaning towards a JBE module - lots of relay clicking noises coming from the passenger footwell area, random failure codes for taillights that are obviously not failed .. all of these codes are power related, etc
Old Mar 13, 2026 | 04:18 PM
Maybe, maybe not
Community Builder
Just to clarify, are you saying that after clearing the codes, all the codes return after turning the ignition ON without starting the engine?
sully325's Avatar
sully325
Yes, exactly
Old Mar 13, 2026 | 04:21 PM
sully325's Avatar
sully325
Yes, exactly
Actually, NO, strike that ... the codes reappear only after starting the engine after clearing them in the case of the CAS codes ... only after putting the car in motion for the DSC codes
Old Mar 14, 2026 | 10:40 AM
Maybe, maybe not
Community Builder
Start here:
Clear all fault codes again, and then use your Foxwell scan tool to recalibrate the steering angle sensor. When done, drive the car to see whether the DSC fault codes do not return.
Old Mar 14, 2026 | 10:44 AM
sully325's Avatar
sully325
Checked steering angle sensor when this first started - it is correct
Old Mar 14, 2026 | 11:23 AM
Maybe, maybe not
Community Builder
Did you do the recalibration procedure? And can you describe how you assessed the steering angle readings?
Old Mar 14, 2026 | 11:40 AM
sully325's Avatar
sully325
yes, recalibration was done - read via scanner with vehicle running on level ground, steering wheel straight, read 0deg
Old Mar 14, 2026 | 11:59 AM
Maybe, maybe not
Community Builder
Use your scan tool to graph the CAS module voltages at both terminal 30 and terminal 15 before and after you start cranking the engine. Post your graphs.
Old Mar 14, 2026 | 01:11 PM
sully325's Avatar
sully325
Top to bottom = from fob inserted, crank, engine running
Today the car is also intermittently not starting on the first push of the button ... Starter flutters like low voltage, then the car will start after the 3rd or 4th push of the button - battery, again, is brand new and passes load test, yes, it was coded to the car
Thank you for all your input, btw, I have been remiss in saying that 🙏
Old Mar 14, 2026 | 01:27 PM
Maybe, maybe not
Community Builder
Interesting.
However, you only mention three conditions above but show 4 images. Please list the four conditions matching the images.
Can I assume that the second image is the initial cranking?
Old Mar 14, 2026 | 01:32 PM
sully325's Avatar
sully325
Since I can't post a video, there is a few seconds in photo snaps ... 1 key fob inserted, 2 cranking, 3 continued cranking, 4 engine has started
Old Mar 14, 2026 | 01:35 PM
sully325's Avatar
sully325
JBE is now popping a code as well
Old Mar 14, 2026 | 02:00 PM
sully325's Avatar
sully325
#3, 5 &6 are saying the failure is due to no message from the CAS transmitter
I'm just about convinced that the CAS module has given up
Maybe, maybe not
Community Builder
Image #2 reveals the likely underlying issue causing all of the problems. During cranking, the terminal 30 and terminal 15 voltage should not drop below 9.6V. Your voltages drop as low as 8.6V, likely causing the CAS to stop processing (code A0A9), the DSC to reboot, and the JBE to stop receiving voltage from the CAS (code C91E).
Possible causes of the low voltage spike:
1) Excess resistance in the engine ground wire.
2) Excess resistance in a battery-connector to battery post connection.
3) Excess resistance in the battery cable to starter/alternator harness connection.
Old Mar 14, 2026 | 02:26 PM
Maybe, maybe not
Community Builder
My interpretation of code C91E is that the excessive voltage drop during cranking prevents the CAS module from communicating with other modules on the CAN-bus.
Another possible cause of the cranking voltage drop is a faulty starter motor that draws excessive amperage.
A simple way to test for a bad engine ground wire is to connect one end of a battery jumper wire to the (-) battery terminal and the other end to a clean, unpainted bolt on the engine block. Then redo the Foxwell voltage drop test.
Old Mar 14, 2026 | 02:36 PM
sully325's Avatar
sully325
I did remove and clean the ground points on the engine and chassis, the strap itself does not look to be corroded but I'll replace it anyways. I may get the neg cable for the battery as well. I'll post back with the outcome.
Thank you so much for taking the time to help with this problem!
Old Mar 21, 2026 | 03:11 PM
sully325's Avatar
sully325
So, thanks to maybe, maybe not, I think this problem is solved! It was the starter - I went ahead and replaced it about a week ago, cleared codes and have had zero problems since ... Thank you soooo much, maybe, maybe not ... Lifesaver!
1974usna
Jun 25, 2025 10:18 AM
dingels75@msn.com
Jul 24, 2021 10:15 AM
asmasm
Sep 14, 2016 07:14 AM
Agbullet25
Oct 31, 2014 12:42 AM
BlimeyCabrio
Jun 13, 2009 12:44 PM
