R50/53 2005 MINI Cooper R50 (CVT) – No Crank, Starter Tests Confusing
Hi everyone,
Very sad to write this but my Mini is pretty sick. It failed to start and I’m trying to figure out why. I'm going to try to be as detailed as possible about what happened and what I did so far. A couple of days before it completely died, I had one or two instances where it wouldn’t start on the first attempt: no cranking sound at all. I didn’t think much of it and assumed I hadn’t fully turned the key. After that, it progressively got worse and eventually stopped starting altogether. Roadside assistance tried to jump-start it, but that failed. There was no sound whatsoever. I had to tow it home.
This what I so far had checked:
Battery & Basic Checks
Starter Circuit Testing
I checked voltage at the starter:
I removed the starter and tested it outside the car:
Summary of Observations
- Battery resting voltage: ~12.65V
- Voltage drops to ~11V while attempting to start
- Fuel pump primes
- Windows, fans, lights all work normally
- 12V at the main positive terminal
- Good ground at the motor casing (12V)
- Voltage drops slightly (~11.5V) during crank attempts
- 12V at the trigger wire when disconnected from the solenoid
- 0V at the trigger wire when connected to the solenoid during crank (this seems odd?)
- Jumped it directly using the car’s battery
- Starter engages and spins normally
- I see about 11V at the trigger wire while the starter is engaged
- Battery appears healthy enough.
- Starter motor works when triggered directly from battery.
- Car sends 12V to trigger wire when disconnected while attempting to crank
- Trigger wire shows 0V when connected to solenoid during crank. Is this normal?
- Starter will crank when manually jumped, but not using vehicle’s trigger circuit.
- A bad starter solenoid?
- A wiring issue in the trigger circuit?
- High resistance somewhere in the control circuit?
Just found this thread about the ignition switch that seems eerily similar to what I’m experiencing: https://www.northamericanmotoring.co...on-switch.html
I assume you tried to start in PARK, did you try in NEUTRAL? If it works, I would guess the Sensor/Switch that tells the car the transmission is in PARK may be bad or out of adjustment.
Best of luck.
Motor On!
Best of luck.
Motor On!
Confirmed that my ignition switch has a high resistance (4-6 ohms) between pins #5 and #8 in the crank position. Those pins close the starter trigger circuit and should have 0 ohms. I will be getting a new switch and starter (because why not) tomorrow.
Mini is back from the dead and running again! Turned out to be the ignition switch (I installed a new Vemo unit). Seeing 12V at the starter trigger wire when it wasn’t connected to the solenoid initially made me think the starter itself was bad. Since I had already removed the original starter for bench testing, I went ahead and installed a refurbished Bosch unit while I was in there. A couple of notes for anyone doing this job: despite what the Bentley manual says, you do not have to remove the exhaust manifold to replace the starter. There’s also no need to remove the wheel to access the lower bolt. The whole job can be done from above after removing the heat shields.
Hopefully this helps someone chasing a similar no-crank issue. Thanks for all the replies!
egoaudio
Mar 1, 2024 12:28 PM
Boarding00n
Sep 9, 2023 08:03 AM
R50/53 Starter Voltage, 2004 R50
ChrisOhle
May 18, 2019 02:13 PM
sixece
Feb 15, 2019 05:49 AM
BuffMyRadius
Jul 20, 2015 12:06 PM
