R56 Assitance Locating Oil Leak
Old Jan 31, 2026 | 06:27 PM
gatorbait01's Avatar
gatorbait01
Hey Guys,
Wondering if any of you might assist me pinpoint the source of an oil leak I have on a R56 S N14. I actually have a coolant leak and oil leak. I was confident it was the oil filter housing seals due to seeing both oil, and coolant which I had replaced last year and was thinking it was a bad install. I took my car apart today and after taking off the heat shield off the downpipe I was surprised it doesn't look wet in that area. Now after closer inspection, I think the antifreeze leak has to be the thermostat housing, but I'm not seeing where this oil leak is coming from. It doesn't seem to be coming from the oil pan. I do have a small leak on the crank seal, but I'm not sure where this oil is coming from. Any of you have any ideas on the source of the leak from the pictures? Your help would greatly be appreciated.
Side View Oil Filter Housing
Bottom Up Oil Filter Housing
Oil Drippage, Doesnt look like its coming from the oil pan.
Oil Drippage, Doesn't look like it's coming from the oil pan.
Both oil and antifreeze
Some antifreeze drippings, Top down
Old Feb 1, 2026 | 06:50 AM
gatorbait01
Maybe rear main seal? Seems likely.
Old Feb 1, 2026 | 10:46 AM
Raymo2u's Avatar
Raymo2u
Originally Posted by gatorbait01
Hey Guys,
Id check your Water Pipe and Thermostat for antifreeze leaks. If you look at your CVs, it looks like its dripping on to them and then being flung everywhere.
The oil leak could be a slow RMS leak, or the large Allen bolts behind the Flywheel. I dont see any residual from the Oil Cooler or Turbo Feed Line.
Old Feb 1, 2026 | 03:19 PM
mkov608's Avatar
mkov608
Concur ... looks like both of your main seals are leaking ... lots of oil and dirt accumulation on the block behind the alternator. I've used UV dye in the oil to help me find leaks in the past. It's available on Amazon.
Old Feb 1, 2026 | 06:59 PM
gatorbait01
Thanks for your inputs. The rear seal looks like a PITA to replace. Will clean it up and try the dye to try to confirm.
Old Feb 2, 2026 | 11:44 AM
Rear main seal its looks like to me.
https://www.northamericanmotoring.co...st-post-2.html
Island_Moose
Mar 30, 2019 04:13 AM
broncobuddha
Oct 24, 2017 11:11 AM
ssashton
Mar 8, 2017 09:23 PM
03miniS
Mar 12, 2010 01:46 PM
22CooperS
Dec 26, 2007 07:29 AM
