R50/53 Engine ON or OFF for Transmission Fluid Level Adjustment
Old Jan 23, 2026 | 10:37 AM
MikeW2's Avatar
MikeW2
Hi all,
Car: 2005 Mini Cooper R50 hatchback, CVT. No level tube — it has the front-facing level/overflow plug plus drain/fill plugs.
I’ve done a few drain/refill exchanges and want to make sure the final level set is correct. Most guides (including this forum's from How-Tos section) say the level check is done with the engine ON, at a specified fluid temperature, but I’m trying to confirm what the actual MINI/BMW dealership procedure is for this CVT.
If anyone has access to the factory steps or has done this at a dealer, can you share the exact procedure? Thanks!
--Mike
Old Jan 24, 2026 | 02:53 AM
mkov608's Avatar
mkov608
Hey Mike, I have access to the TIS (Technical Information System) through AllData. Send me an IM and we'll connect so I can get the required information on your car.
Old Jan 24, 2026 | 05:42 AM
WhoHasGotTheBlueS's Avatar
WhoHasGotTheBlueS
I can’t answer the question you have asked. But, I can tell you that the Bentley manual outlines an involved CVT fluid change procedure, with caveats about exhaust gasses, i.e. engine is on for at least part of the process. I don’t know if the information they provide is the factory procedure.
Old Jan 24, 2026 | 12:28 PM
MikeW2's Avatar
MikeW2
In the Bentley manual, part of the procedure involves lifting the front wheels off the ground and revving the engine in D to about 2500 rpm.
I’m planning to skip that step. I don’t have access to a proper hoist, and I’m also not comfortable revving the drivetrain with no load on the wheels. Free-revving in gear with the suspension unloaded doesn’t seem like something I want to do outside of a controlled shop setup.
Old Jan 24, 2026 | 02:07 PM
MikeW2's Avatar
MikeW2
Correction: they just remove the wheels rather then attach to a hoist.
Old Jan 24, 2026 | 04:12 PM
noodlesandsam's Avatar
noodlesandsam
Every Automatic I have ever checked is done running. Manual transmissions are done off. BMW / Mini have temp values of when you check on BMW, and for the 6 speed automatic on Mini r53.
Old Jan 24, 2026 | 05:43 PM
noodlesandsam
Do a search. I had issues with a url.
  • Preparation: Ensure the car is on a level surface, preferably using a lift or four jack stands to keep it level. The engine must be running.
  • Temperature Check: The transmission fluid should be between 95F and 115F
but again - runnung
Old Jan 29, 2026 | 09:14 PM
MikeW2's Avatar
MikeW2
In case anyone wondered, the difference is about 600 mL. Thanks for the replies!
Andrew Kakritz
Oct 10, 2020 10:39 AM
Black Forest
Apr 20, 2017 08:27 PM
YELLOWMINIAZ
Jul 3, 2011 06:43 PM
rehsper
Sep 26, 2010 04:41 PM
