Replacing a Double Din head unit in an R56/7 with an existing Double Din Conv
Old Nov 13, 2025 | 03:25 PM
gauss66's Avatar
gauss66
Hi ! I am going to help a friend on his Mini. He has an R57 with a Double Din head unit already installed ( I believe it was a Crutchfield Metra kit with a Kenwood Double Din ). He wants to replace the Double Din unit with another Double Din unit. Silly question - but do you have to remove all the dash stuff like you do when converting to a double din unit or can the existing double din unit be pulled out with clips. It already has all the wiring done - in hopes that it is long enough so that it can be pulled out LOL
TIA
Old Nov 16, 2025 | 07:01 PM
bluonyx's Avatar
bluonyx
You'll probably have to remove all the dash stuff again. You can't remove the front console panel without taking off the speedometer cluster trim. Be sure to have a free hour for everything. GL!
Old Nov 24, 2025 | 03:31 AM
PeaceVam's Avatar
PeaceVam
TIA
Steps to take:
1) tach;
2) 2 inserts (or just one if you have a secret glove box compartment);
3) speedo trim;
4) lower driver knee trim panel;
5) left and right center console trim panels;
6) cup holders and 12v socket panel
troyegly
Nov 23, 2021 07:29 PM
id-inspired
Feb 1, 2009 05:56 PM
elenex
Mar 7, 2004 06:16 PM
