R50/53 New strut mounts are looking different that expected
Old Oct 18, 2025 | 08:15 AM
kgardnez's Avatar
kgardnez
After 4 months of “fixing” the R50 we bought no running we are driving for the first time and I’m surprised by what I’m seeing with the URO strut mounts.
First time these saw load was yesterday as the car was on jack stands.
Is the height of the strut and the cracking of the rubber surface normal?
Old Oct 18, 2025 | 09:55 AM
noodlesandsam's Avatar
noodlesandsam
You did buy URO. They do not have the best reputation for longevity. That does look like cracking of the coating that is applied. Keep an eye on it, and watch for actual cracks between the rubber and steel. Also listen for clunks. There is also a thread from someone who had lots of issues with upper mounts. Are you sure things went back in the right order? I’ve done a few on mine in 20 years - Used Lemforder - never had issues. Current ones are 6 years old?
Old Oct 18, 2025 | 11:43 AM
deepgrey's Avatar
deepgrey
That looks like a failed mount. I don’t remember the stock mounts sitting that high.
Old Oct 18, 2025 | 11:51 AM
kgardnez's Avatar
kgardnez
Disappointing, but this is how you learn
I’m thinking a swap to Lemforder or ECS heavy duty might be warranted.
also thinking to add Cravespeed UTI or the Hamburg Tech plates.
https://www.cravenspeed.com/under-to...sM#tab-reviews
https://www.pelicanparts.com/More_In...jK_SwWz2uBDgCb
Old Oct 18, 2025 | 11:55 AM
deepgrey's Avatar
deepgrey
Read this thread.
Old Oct 18, 2025 | 12:42 PM
Jonny's Avatar
Jonny
Lemforder is now a made in China product, not recommended. Go with OEM or Ireland Engineering ( which have HD bearings and are rebuildable).
Old Oct 18, 2025 | 12:43 PM
kgardnez's Avatar
kgardnez
Does the Ireland Engineering product negate the need for other reinforcement plates?
Old Oct 18, 2025 | 12:51 PM
Jonny's Avatar
Jonny
Yes, they are basically underators, which is much better protection for the strut towers (mushrooming) than top mounted strut defenders. I believe they also add an additional 1* of camber.
Old Oct 18, 2025 | 12:53 PM
cooper48's Avatar
cooper48
FYI. Reinforcement plates are to strengthen the strut towers, not the struts themselves. Your towers may have also "ballooned" which is a common problem on Gen 1 Mini's. See ModMini on YouTube for a corrective measure.
Old Oct 18, 2025 | 01:26 PM
kgardnez's Avatar
kgardnez
Son just came home in the mounts are definitely failing
The idea of Irish engineering mounts is good, but quite the price increase!
oof, to add insult to injury IE wants $30 shipping!
Old Oct 18, 2025 | 02:19 PM
Jonny's Avatar
Jonny
Both IE and OEM aren’t cheap. But there are certain components you don’t want to cheap out on. This is one of them.
Old Oct 18, 2025 | 02:44 PM
kgardnez's Avatar
kgardnez
This vehicle is a 3/2002 which seems to be a changeover time I'll need to look into, this whole thing is reminding me of my R53 made in April 2004 which bridged some changes (bit me in the behind several times)
Old Oct 18, 2025 | 08:07 PM
noodlesandsam
Look at post #19 of this thread
https://www.northamericanmotoring.co...er-plates.html
Old Oct 20, 2025 | 11:45 AM
ssoliman's Avatar
ssoliman
there was a post on this recently that covered this topic. it went deep. i think others have mentioned it here / above
Old Oct 20, 2025 | 03:25 PM
GLEX's Avatar
GLEX
Originally Posted by deepgrey
Checking in as the guy who started that thread and was pulling my hair for weeks. The genuine MINI mounts that I eventually put in are going strong. Mounts from ECS, Lemforder, URO, etc. are likely to immediately fail, like I experienced and seen again here. "OEM" isn't good enough - buy genuine or go with coilovers that have solid camber plates.
Old Oct 20, 2025 | 03:55 PM
kgardnez's Avatar
kgardnez
This is so strange as on my R53 I had Koni reds with KYB strut mounts and never saw any issue
Old Oct 20, 2025 | 05:08 PM
noodlesandsam
Times have changed. There are lots of poor quality parts out there.
Old Oct 20, 2025 | 05:37 PM
GLEX's Avatar
GLEX
Yep, I can only assume that lower quality rubber is now the norm, even with once reliable brands like Lemforder.
Old Oct 21, 2025 | 09:39 AM
Here2Go's Avatar
Here2Go
NAM Community Team
Yep - Curious after reading this thread; I too decided to check the torque and the condition of my top Lemforder mounts I'd installed only 6k - 8k mi ago. With cooler temps in the morning @47° they are starting to creak and noticed how bulged they were. Not as bad as the OP's - (tops are perfectly level with the opening), but just the same. These parts are getting expensive. To the point ; I don't know what brand to trust anymore.
Old Oct 21, 2025 | 10:27 AM
Jonny's Avatar
Jonny
I believe Lemforder began switching their manufacturing of many parts to China during Covid. Quality dropped like a rock, as expected.
Old Oct 21, 2025 | 03:13 PM
GLEX's Avatar
GLEX
This seems to be the issue. I installed some other Lemforder parts recently (either outer ball joints or end links) and noticed they were marked as being made somewhere in Europe (Slovenia? I can't remember). Unfortunately, the now made in China strut mounts are garbage. So that leads to the question of who (or where) are the genuine MINI mounts coming from, since they're still good.
Old Oct 21, 2025 | 03:23 PM
kgardnez's Avatar
kgardnez
I’m wondering if there aren’t different sources for some items such as Lemforder as ECS assured me that theirs are from Germany.
Old Oct 21, 2025 | 03:33 PM
GLEX's Avatar
GLEX
Who knows. I went through two sets of ECS "heavy duty" mounts. They looked and were packaged nicer than the Lemforder and genuine mounts, but failed even faster than the Lemforder set I tried first.
GLEX
83
Jan 27, 2026 05:41 PM
mdurando
Apr 26, 2024 06:49 AM
GJenkins82
12
Jun 24, 2023 07:14 PM
Mini Cooper S
Suspension
59
Mar 1, 2006 05:30 AM
