Hello, I have a question about which fuse you would recommend using for dashcam power. My vehicle is a 2012 Base Model Cooper Hardtop (so alot of these fuse plugs are non powered). I used the Youtube video to get everything else installed and grounded correctly so that is all well. Currently I have a temporary fuse tap going to the cigarette fuse (Location F44) however that fuse will not be ideal long term because it is a larger fuse and I am unable to install the fuse cover back on. I also looked at using F16 however that is a constant hot. I checked out F22 my vehicle doesn't have that feature as well. Looking from F1 to F53 are there any other spots that could be a potential source of keyswitch power? Radio perhaps? Below is my fuse cover panel.
It powers the module for the parking (backup) sensors in the bumper. Being that your a base Mini you shouldn't have them, and the fuse is just in there.
If you have the circles in your bumper (see pic) then you have backup sensors.
