Combustion Misfires
Old Jul 31, 2025 | 02:41 PM
Addco's Avatar
Addco
Combustion Misfires
2015 Cooper S Roadster. N18 engine.
Coming out of a high-speed corner in third, floored it, just about to shift to 4th, engine misfires, CEL comes on, goes into limp mode.
several codes all related to “Combustion Misfires”:
2EFE
2F00
2EE0
2EE7
2F02
2EED
2EE1
2EEF
Where do I start looking?
Old Jul 31, 2025 | 03:45 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
https://bmwfault.codes/Lookup
The fault codes seem to indicate misfires in cylinder 2 and cylinder 4 and to suggest testing of the fuel supply, ignition, air supply, engine cooling, and engine mechanics.
Old Jul 31, 2025 | 04:03 PM
Addco's Avatar
Addco
Wow! That narrows it down. 🤣
Old Jul 31, 2025 | 04:12 PM
Maybe, maybe not
Community Builder
Do you have a scan tool that reads live data? If so, you can start by checking fuel pressure from the HPFP and the engine coolant temperature.
You can also swap spark plugs and coils between cylinders; verify the engine mechanical timing; and check for clogged fuel injectors.
Old Jul 31, 2025 | 05:05 PM
Addco's Avatar
Addco
Yes. HPFP runs around 1100 at idle & around 1700 while running. Coolant temp stays around 200°f. I was gonna throw a set of coils & plugs on it since it’s never been done as far as I can tell. 90k miles on the car. I’ll look into the timing & injectors. Thanks.
Old Jul 31, 2025 | 05:54 PM
Maybe, maybe not
Community Builder
Originally Posted by Addco
I was gonna throw a set of coils & plugs on it since it’s never been done as far as I can tell...I’ll look into the timing & injectors. Thanks.
Sounds like a good plan.
I'm hoping plugs and coils are the solution.
Old Jul 31, 2025 | 07:32 PM
spaktacular's Avatar
spaktacular
2EFE
2F00
2EE0
2EE7
2F02
2EED
2EE1
2EEF
Just for giggles....check your oil.
Old Aug 1, 2025 | 09:42 AM
Addco's Avatar
Addco
Oil looks good & clear. No coolant in it.
Might have a slight fuel smell. Hard for me to tell. My sniffer is not so good anymore. 🙃
Old Aug 1, 2025 | 10:11 AM
Maybe, maybe not
Community Builder
^Wouldn't be surprising or unexpected given the engine misfiring.
Old Aug 5, 2025 | 04:30 PM
Addco's Avatar
Addco
Update: Fixed
Installed a new set of plugs and coil packs. Cleared codes and went for a test drive.
Runs like new again !
Thanks to everyone who responded. Cheers!
Old Aug 5, 2025 | 04:35 PM
JAMADOR's Avatar
JAMADOR
I'd say keep an eye on it.
I did new coils/plugs back in Oct 24 & just had my misfire return.
capncam
Apr 2, 2026 07:45 AM
mx915
Electrical
May 16, 2025 10:16 PM
Tobi151297
European MINIs
Oct 7, 2023 01:02 PM
mscarano
Dec 9, 2018 05:05 AM
Tech69
Jul 20, 2014 07:47 AM
