R56 Need help finding the fuel tank breather valve ~~
Old Jul 8, 2025 | 02:52 PM
MiniVelvet's Avatar
MiniVelvet
Hello folks I am trying to narrow down the possible culprits leading to random misfiring. The fuel tank breather valve is one of the last few things that I can tackle before taking it to a shop again. I can't seem to find it in the engine bay, with or without my glasses on. I can almost squeeze my head in between the engine and firewall. Pictures below show the area that I have access to, with the air box and pipes out. Any guidance is appreciated!
2011 MINI Hardtop Base 6MT with 203K miles
Old Jul 9, 2025 | 01:08 PM
Its down under that intake manifold. Its a pain.
https://bmwrepairguide.com/mini-r56-...2013-cooper-s/
MINI R56 water pipe replacement - Fuel line vent valve
https://www.realoem.com/bmw/enUS/sho...03#13907624538
https://www.ecstuning.com/Search/Sit...h/13537543286/
Old Jul 12, 2025 | 01:41 PM
MiniVelvet's Avatar
MiniVelvet
Thank you so much for the pics and link! It was already a pain to locate it. Let's see how far I can go now that I have a mental picture of what's going on back there...
Old Jul 14, 2025 | 08:26 AM
Welcome, glad to help.
Old Jul 18, 2025 | 12:23 AM
MiniVelvet's Avatar
MiniVelvet
I was only able to loosen up the 10 mm bolt and bracket from the top. The valve was out of sight and difficult to grab. Since I rented a lift for an afternoon, the shop owner helped me replace it by working from under the car (on the lift). It was easier to see and access from under. 😂 It wasn't the culprit of my problems though. Car ran the same on my way home. Next week I will replace the valve cover gasket.
Old Jul 18, 2025 | 06:08 AM
Oh, that stinks. Let us know what you find.
Old Jul 19, 2025 | 12:24 PM
MiniVelvet's Avatar
MiniVelvet
All the spark plugs had oil on them so the tube seals are definitely out. I hope a new valve cover gasket will fix it. It doesn't run rough until a few miles after getting up to temp, and only when the rev is down below 2K.
Car is due for smog in August.
Here2Go
Sep 2, 2024 01:54 PM
Chris266
Feb 23, 2022 04:35 PM
Phillbis
R60/R61 Stock Problems/Issues
Nov 16, 2021 07:56 AM
mikeym
Jan 6, 2013 05:40 AM
ronstoys1
Jan 21, 2007 05:30 PM
