Another crank but no start issue
'm trying to solve the no start problem on my friend's 2008 R52 convertible. A local mechanic who claims to "know foreign cars" simply threw parts at it- plugs, relays, cam position sensors,etc. He also told her that his computer wouldn't connect to the car and he couldn't do a diagnosis - All BS IMHO.
Here's what I know. The car ran about a year ago (after sitting for 6 months) but then the battery died prior to the owner's attempt at starting it. It was jumped but wouldn't start. The battery was subsequently replaced.
Fast forward to now. I was able to scan it using my Autel MaxiSys tool and got a 1656 immobilizer DME EWS "incorrect code" . In addition there was a 500 fault DME,vehicle speed signal fault, though I don't think that's related.
All of this would suggest the common problem that I've read about in multiple posts, the out of alignment issue. Does that make sense? If not,what should I be looking at? Assuming it's the alignment problem, is it reasonable to expect that I'll be able to use one of the cables available on Amazon (or elsewhere) and the ISTA software to solve the problem? Is there a preferred cable? Where should I source the ISTA? I don't think my Autel will handle that.
A K+DCAN cable. Look for one with the switch to bridge pins, which is mandatory to work for first gens (you can modify one yourself but it's a pain)
No clue, but (like INPA), it's not available to the general public, so you'll have to get a pirated version somewhere.
Air, spark, fuel. Have you verified you have spark and fuel in each cylinder?
It sounds like the car has been sitting for months with a dead battery. I'd clear all the codes, verify you have spark and fuel, then give it a crank. Then see if any codes come back. I've seen dead batteries cause all kinds of confusion and codes. Reset it and start fresh.
rob_jones
Jan 22, 2023 10:01 AM
Strange
Feb 23, 2020 06:24 AM
Strange
Feb 22, 2020 04:44 PM
