F55/F56 F66 JCW Wheels on F56 JCW? Spacer Size?
Old Jun 18, 2025 | 11:58 AM
Bred's Avatar
Bred
I have a set of F66 2025 JCW Wheel take offs I want to fit to my F56 JCW. Given the change to the brakes on the new 2025 JCW, they appear to need spacers to work. Anyone tried this or have an idea how much of a spacer might be required? Any insight would be appreciated!
Old Jun 18, 2025 | 12:53 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If you already have the wheels and the car.... Just go out and try them on!
Old Jun 18, 2025 | 01:06 PM
Bred's Avatar
Bred
Yep. Did that - can't figure out how many MM I need and was trying to learn from someone who may have done it. Hate to buy spacers that don't work :-) or are more than I need.
Old Jun 18, 2025 | 01:16 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Here's a brief explainer of what I did...
Mount the OEM wheels. Measure the clearance from the brake disc to the back of the wheel spokes, both at the outer edge of the rotor and down near the hub. The, remove the OEM wheel, and remove the brake caliper and tie it out of the way. Then, mount the new wheels and measure the clearance from the brake disc to the back of the wheel spokes, both at the outer edge of the rotor and down near the hub. Compare the two sets of measurements, and see how much spacer you need to get the same clearance for the new wheels.
Old Jun 20, 2025 | 08:16 AM
+1 ^^
Old Aug 24, 2025 | 11:58 PM
blue al's Avatar
blue al
this may seem like a sledgehammer to crack a nut, but it’s far easier to rotate your wheels with 2 pins, so I have 2 already
Make sure you have clean wheels 1st….
“ other brands are available “
POWERALIGN WHEEL MOUNTING GUIDE PIN
PF99-514-125
Use guide pins and a stack of fat washers “ as spacers” you’ll will need at least a pair,
add one wheel bolt with same quantity of fat washers to oppose the guide pins ( the fiddly bit)
hang wheel, nip in 2 other bolts, to ensure its sat square, and no gaps in washers.
check calliper clearance (say one washer ) spin wheel checking for movement
then measure once on the hub, and secondly washer stack
as final sanitary check, count each set of washers.
buy spacer,….relax
Old Aug 26, 2025 | 10:04 AM
This is what we use.
https://www.ecstuning.com/b-ecs-part...202ecs03lktkt/
Old Aug 27, 2025 | 05:45 AM
trlman's Avatar
trlman
Wheel fitment
Simple, place both wheels upside down. Place straight edge on mounting surface, and measure distance to spokes. Difference is thickness of spacer.
Gelmobile
Mar 30, 2025 12:50 PM
Ch28Kid
Mar 11, 2020 08:52 AM
marvinclick
Jan 9, 2018 06:25 AM
Mini Donuts
Dec 1, 2016 08:05 AM
Ryephile
Detailing 101
Sep 16, 2015 06:32 AM
