R56 Inconsistent A/C refrigerant charge specifications on hood label & in service manual
Old Jun 12, 2025 | 10:39 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
2012 base-model hardtop
Please see images from hood label & service manual below.
Note that all of the R134a weight specifications are DIFFERENT. Which is correct?
Hood label:
In German, R134a specification is 460 +/- 10 g [Conversion from grams to pounds or ounces: 1.01 lbs or 16.2 oz]
In English, R134a specification is 0.91 +/- 0.02 lbs [Conversion from pounds to grams or ounces: 413 g or 14.6 oz]
Service manual:
R134a specification is 490 +/- 10 g [Conversion from grams to ounces or pounds: 17.3 oz or 1.08 lbs]
R134a specification is 15.8 +/- 0.4 oz [Conversion from ounces to pounds or grams: 0.99 lbs or 448 g]
Old Jun 26, 2025 | 12:51 PM
mkov608's Avatar
mkov608
Always go with the hood label, unless the hood came from another car due to an accident.
Old Jun 26, 2025 | 01:02 PM
Maybe, maybe not
Community Builder
And there lies the problem. The hood label (original for the car) lists two different R134a weights. Which is correct?
To make this even more confusing, the two weights listed on the hood label differ from the weight found in the Bentley factory service manual.
Old Jun 26, 2025 | 01:07 PM
mkov608's Avatar
mkov608
Use the 1.01 spec.
Old Jun 26, 2025 | 01:15 PM
Maybe, maybe not
Community Builder
Use the 1.01 spec.
Please explain.
Old Jun 26, 2025 | 03:00 PM
mkov608's Avatar
mkov608
Explain what? Why I said to use the 1.01 spec? That's what's on all of the R56s I've restored.
Old Jun 26, 2025 | 03:28 PM
Maybe, maybe not
Community Builder
Are you saying that 0.91 +/- 0.02 lbs is NOT also on those same labels?
Old Jun 26, 2025 | 09:58 PM
giorgos's Avatar
giorgos
Here's the label on my 2010 LCI with 534 (automatic air conditioning).
PS: This is not the first time I come across data in the Bentley manual which is apparently either wrong or does not cover all production variations of the series (e.g. torque values).
Old Jun 27, 2025 | 06:06 AM
Maybe, maybe not
Community Builder
Thank you, that's extremely helpful information! I wonder if all USA MINI LCI hood labels have the same R134a weight conversion error present on my hood label.
To other members: Please post a picture of your MINI hood label showing the required R134a weights in grams & lbs.
Old Jun 27, 2025 | 07:13 AM
This is the sticker i have on my original hood. 2012 R58 JCW with the N14 engine.
https://www.ecstuning.com/b-genuine-...n/64506916084/ Thats the part number in the bottom right hand corner
But my sticker says Fullmenge 460 +- 10g so at one point they updated it to 415. Picture was in 2014 time stamp.
Hope that helps.
Old Jun 27, 2025 | 08:10 AM
Maybe, maybe not
Community Builder
Hope that helps.
Very interesting and helpful.
For the label shown in your picture, the R134a weight in grams and lbs matches (correct conversion), unlike my label.
Does your sticker with Fullmenge 460 +- 10g show the correct conversion to lbs (1.01 +/- 0.02 lbs) or the incorrect conversion (0.91 +/- 0.02 lbs) like mine?
Old Jun 27, 2025 | 08:38 AM
Old Jun 27, 2025 | 08:46 AM
Maybe, maybe not
Community Builder
Haha...incorrect conversion just like mine. Thank you!
I would assume that there are some DIYers and shop techs who were misled by the label error and improperly filled MINI A/C systems with the incorrect weight of R134a.
Old Jun 27, 2025 | 08:57 AM
Yep, my guess is it was wrong till 2013.... then MINI got a new batch in with it correct! Hence our update time stamp photo
So ever Gen 2 MINI needs and updated sticker. I would just lay it over the old one.
I am surprised their was not a recall for an updated label???
YARN | l guess that's another mystery. | Scooby Doo, Where Are You! (1969)  - S01E03 Hassle in the Castle | Video gifs by quotes | fb8b33fc | 紗
Old Jun 27, 2025 | 09:22 AM
Maybe, maybe not
Community Builder
Please correct me if I'm wrong. In North America, we're currently not absolutely certain which R134a label is correct, your original label or the updated label.
In your update 2012 label, the R134a weights in grams & lbs match (415 g equals 0.91 lbs).
In your original label and my 2012 original label, the R134a weights in grams & lbs do NOT match (460 g does not equal 0.91 lbs)
In George's German 2010 label, the R134a weights in grams & lbs match (460 g equals 1.01 lbs)
Is the proper R134a charge in North America 415 g or 460 g? Do you see what I mean?
Old Jun 27, 2025 | 10:36 AM
Hello
2012 R58 JCW label, the R134a weights in grams & lbs dont match 460 and 0.91
New label for my car is 415 and 0.91 which is the correct label as that's what we sell. https://www.ecstuning.com/b-genuine-...n/64506916084/
The label company messed up for the stickers in production. They combined USA and Germany labels.
Old Jun 27, 2025 | 01:04 PM
Maybe, maybe not
Community Builder
Hello
Thank you so much for taking time to respond to this thread and for providing accurate information.
Just to verify, the required R134a charge for your 2012 MINI and my 2012 MINI is 415 g/0.91 lb. Is this correct?
Old Jun 27, 2025 | 01:29 PM
giorgos's Avatar
giorgos
With no information on this whatsoever, my gut feeling (and almost 3 decades of living here) tells me that there is absolutely no way a BMW built Mini has any dimension, weight, volume or any other measurement engineered/measured/specified (and subsequently documented) in imperial rather than metric. Hence my 2 cents worth bet goes for whatever metric value is printed on any label, irrespective of whether any non-metric conversion value also printed on it matches the metric or not.
Old Jun 27, 2025 | 02:05 PM
Maybe, maybe not
Community Builder
The scientific community worldwide is completely metric, and I would hope that the same is true for engineers. Imperial units are archaic and serve only to confuse.
However, based on ESCTuning's input, the metric weights were incorrect and the imperial weights were correct on the original hood labels in North America. Who would have thunk?
Clockwork
R55 :: Clubman Talk (2008+)
May 27, 2023 09:20 AM
Danyes
Nov 1, 2020 08:43 AM
Bigdaddy0128
Aug 17, 2012 07:40 AM
Rainforest_Elf
Oct 5, 2010 01:16 PM
SSMini
Aug 7, 2006 07:45 PM
