R50/53 No A/C and No Blower
Old May 15, 2025 | 10:01 AM
Adiru55's Avatar
Adiru55
06 MCS with Auto Climate Control, currently have no voltage to the compressor and only 8 volts to the blower motor, no mater the speed selected. Checked all fuses, and relays, and tried replacing the blower motor resistor, with no change. Anybody got any ideas on where to even begin to trouble shoot this? Could the Auto Climate controller be bad?
Old May 15, 2025 | 02:17 PM
ssoliman's Avatar
ssoliman
if you have checked fuses, relays and grounds you can buy a new auto climate control unit at: https://www.allmagautoparts.com/
Old May 17, 2025 | 12:25 PM
mkov608's Avatar
mkov608
Whoooo slow down. Connect a scan tool and scan for codes in the HAVC control module. I'm not sure on the Gen 1 Coopers, but the Gen 2 coopers have an ambient temp sensor; the AC won't work with it disconnected, but a disconnected sensor will set a code.
Schematic attached.
Old May 17, 2025 | 12:35 PM
noodlesandsam's Avatar
noodlesandsam
It should be the same ambient temp that tells you outside temp - my 05 r53 ( manual a/c ) has one - in the bumper impact bar
Old May 17, 2025 | 12:44 PM
mkov608's Avatar
mkov608
Looking at the schematic for the R53 MCS, I see an ambient temp sensor, coolant temp sensor, and evap temp sensor. All of these are inputs the DME and the DME control power to the AC compressor via the relay. There is also a AC high-side pressure sensor. If the evap temp or AC high-side pressure is below the set point, the DME won't energize the relay; if the coolant temp is too high, the DME will deenergize the relay and there will be no power to the compressor clutch coil. I'm not sure if the DME requires the ambient temp sensor input on the Gen1 for the Compressor to work ... I'll need to read up.
Old May 17, 2025 | 12:47 PM
mkov608's Avatar
mkov608
Oh, look what I found.
rduffner
Jan 30, 2022 02:58 PM
xfarsightx
Mar 23, 2020 01:25 PM
Jordan Smythe
May 20, 2019 07:57 PM
9sec240
Feb 11, 2019 12:10 PM
