R50/53 The original thickness / height of the head
Old Apr 28, 2025 | 11:30 AM
Nervos's Avatar
Nervos
Can't find this info. I have a head, which was resurfaced, but not sure how many times. Are there specs anywhere, how high / thick should be the head originally?
Old Apr 28, 2025 | 05:53 PM
Nervos's Avatar
Nervos
By other words: how do I calculate how thick the head gasket should I use, if I don't have info about the head resurface?
Old Apr 28, 2025 | 10:21 PM
Nervos's Avatar
Nervos
No one, huh? Either way, I figured myself. First of all, I measured the volume of combustion chamber by putting white spirit into it (with leveled upside down head):
It took about 33 cc. I've adjusted it to 33.1 by using https://www.mopar1.us/compression.html and plugging all known OEM numbers into it. I measured the diameter and depth of dished area on OEM pistons, got ~55 mm x ~0.7 mm, i.e. 1.663 cc volume. Piston deck clearance was also measured right on the engine, got ~3.6 mm
Then, I've adjusted the parameters to my new numbers: bore 77.5, HG bore 78.5 and HG thickness 0.9144 (for Cometic Gasket Automotive C4308-036), not dished pistons (Wiseco) . And I am getting just very slightly higher CR (~8.4):
Meaning, I really need the thicker 0.036" (0.91 mm) HG (vs standard 0.65 mm one) for my build.
Old Apr 29, 2025 | 11:53 AM
ssoliman's Avatar
ssoliman
i did not realize you could calculate hg thickness in this way. are you going for stock CR?
Old Apr 29, 2025 | 12:35 PM
Nervos's Avatar
Nervos
Yes. All I need is stock CR. Basically, just fixing the motor (with more reliable parts), rather than modifying it for higher perf.
Old Apr 30, 2025 | 08:20 AM
ssoliman's Avatar
ssoliman
i'm with that. going for reliability. these cars are plenty fast, stock
Old May 7, 2025 | 02:55 AM
ArrowLockwood's Avatar
ArrowLockwood
Check manufacturer specs or forums; someone might have the dimensions!
redwhiteR562007
Jan 21, 2023 03:57 AM
LetsMini
18
Oct 31, 2005 01:38 PM
