R56 Code P12A1 after new turbo...
Old Apr 15, 2025 | 02:09 PM
Raymo2u's Avatar
Raymo2u
P12A1, Turbocharger Boost Pressure, Pressure Front of Throttle Valve too Low.
After putting in a new clutch and all supporting hardware I was reinstalling my downpipe and somehow stripped out the threads on the turbo manifold. I had a spare turbo I could use (F21 Frankenturbo), but after installing I got this code and the car wont stay running. The car ran fine before the turbo. Ive already replaced both fuel pumps and have decent fuel pressure. I have new coils and plugs as well.
If I unplug the MAF, it runs better but will die with throttle. I adjusted the wastegate some, as there was a good amount of play on the flapper...no successful changes. I took off the intake piping to ensure the turbine spun, its very smooth and spins freely. I cant figure this out.
Im probably going to end up replacing the turbo when I can afford to, but it sucks that I wont have the car for a few months until that is possible if I cant get some advice on what I should try next.
Old Apr 15, 2025 | 03:17 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Enter the code here, and surf through the listings:
https://bmwfault.codes
Maybe something is disconnected still after the clutch job?
Old Apr 17, 2025 | 06:58 AM
Raymo2u's Avatar
Raymo2u
I checked everything plug-wise dozens of times, this is what led me to believe that the new turbo is at fault.
Thank you, I bookmarked the site for future reference. I plan on replacing the turbo for one without serious flapper movement. Fingers crossed that solves the issue.
Laned
R60/R61 Stock Problems/Issues
Feb 13, 2025 03:50 PM
Wife's Car...
Oct 26, 2019 01:25 PM
goj210
Apr 24, 2017 01:06 PM
Ladybug-S
Sep 1, 2015 07:07 PM
Ladybug-S
Jul 1, 2014 07:23 PM
