R50/53 Opinions needed on rebuild
Old Apr 13, 2025 | 11:46 PM
PhDaveMini's Avatar
PhDaveMini
02 R53 MCS getting ready to rebuild the bottom end with spare that I have. Current parts list : Wiseco 77mm shelf pistons, king rod bearings, king crankshaft bearings Newman supercharged fast street cam. ARP rod bolts, new bearings and seals for super charger, arp head stud kit, full engine gasket set, cravenspeed 15% pulley, 2% harmonic balancer checked the bore and it’s good and crank and journals all good too. Any else I should consider? Have cat back exhaust single piece flywheel and clutch kit, k&n air filter.
Old Apr 14, 2025 | 06:03 AM
mikehks's Avatar
mikehks
NAM Community Team
i would keep the damper stock size and run a 17% pulley . everything else looks good ,
Old Apr 14, 2025 | 10:01 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Inquiring minds want to know: What's the difference between a 2% damper with a 15% pulley vs. a 17% pulley with a stock damper?
Old Apr 14, 2025 | 10:18 AM
mikehks's Avatar
mikehks
NAM Community Team
with a 2% damper your also spining the accessories faster , creating more drag and taking life away from your alternator and AC compressor.
17% pulley, your only spinning the supercharger faster , the accessories remain the same speed.
Old Apr 15, 2025 | 07:00 AM
LeviCameron's Avatar
LeviCameron
Any update?
Old Apr 23, 2025 | 10:14 PM
PhDaveMini's Avatar
PhDaveMini
Just got done with assembly
Originally Posted by LeviCameron
Any update?
just got done with assembly of the short block. Will start swap sometime next week and probably take about a week to get done as life and work comes first. Will let you know when it’s all together and running.
New cam compared to the stock cam
Short block with my old head in it for pic
Old May 9, 2025 | 01:01 PM
PhDaveMini's Avatar
PhDaveMini
It’s finally in and running!
Took the old motor out on Sunday pulled the head off and tore it down, cleaned up all the ports and opened them up bit. Went thru super charger, cooling system, flushed out heater core, and a few other things. It runs amazing has great pull from about 2700rpms- 7100rpms still being pretty nice to it for the beak in but was brought up with break it in like your going to drive it and heat cycle it with care. Super happy with everything on this build and the outcome it’s a good daily that doesn’t leak anymore oils and hopefully has a long time before it starts burning 1/2 a qt every 250-350mile lol
PhDaveMini
Apr 12, 2025 07:50 AM
PhDaveMini
Mini/MINI BUILDS
Apr 7, 2025 09:13 AM
speedmob
Feb 20, 2017 12:13 PM
KnighTT
Aug 3, 2016 10:02 AM
go_mini_go
Aug 26, 2009 11:47 AM
