Brake rotors with set screw to the left of the bolt hole?
I got a new to me 06 R53 and when checking out the rotors, I noticed there isn’t a set screw to hold the rotor in place while mounting the wheel.
so, I removed the rotor and noticed that the hole for the set screw does not line up in the same location as hole in the wheel hub/bearing. It is to the right of a wheel bolt hole as compared to the rotor which has it to the left.
the rotor is branded Mini so that is OEM. Don’t know what the wheel bearings are.
Could this car have wheel bearings for a different model? Can I find rotors with the set screw that matches up?
it’s a pain lining everything up when trying to bolt up a wheel.
That's interesting. I replaced my rear wheel hubs/bearings when I put R56 trailing arms on my car. I do not remember having any issues with the brake rotor set screws. Perhaps you could use those mounting studs that are available for car with wheel bolts to ease the wheel installation instead of trying to line up the holes in the brake rotor with the holes in the hub with the holes in the wheel?
