N18 Valvetronic issues after cold start, 2dce 2d42 codes
Old Mar 2, 2025 | 08:19 PM
capncam's Avatar
capncam
Howdy
I’ve got a 2011 n18 turbo r56 cooper s with some new trouble codes. I’ve got 130k and new coils recently.
it was running great until it got cold (20°f) I started it that day and it ran like garbage. Misfiring until it warmed up, then threw out a reduced power light.
codes:
2dce- valvetronic no adjustment possible
2d42 valvetronic stop not learned
Now that it’s warmed up I turned the valvetronic servomotor behind the head with a 4mm hex and it would start and run better after I cleared codes. Still in limp mode though, and once i turn it off and restart the car it will not start well and the servomotor goes to the position it started in (all the way out). If I adjust it again it will start fine. Sometimes it will run fine and keep a CEL on but not be in limp mode. I don’t think there’s any internal damage for this reason.
My thoughts are to replace the valvetronic servomotor first. I’ve heard I need to reprogram after doing this, but also heard it’s not necessary.
If that does not work I wonder if it’s a dme or programming issue.
I don’t have any of the bmw tools (inpa, ncs expert, etc) but my thoughts are to download those and get the cable to start using them. I could reset the cas and start there.
Does anyone have any ideas about where I should start? Or any other ideas as to the source of this problem?
Old Mar 4, 2025 | 09:39 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
On cold start, the N18 engine air control is done using the throttle plate valve in the throttle body. Once the engine warms up a bit the throttle valve goes to full open and the intake air management switches to variable intake valve lift. The point of variable intake valve lift is to eliminate the pumping loss at low RPM caused by the partially opened throttle plate. You'll see this if you have a boost gauge of monitor the intake air pressure, on cold start it will show vacuum which is the engine pulling against the mostly closed throttle valve. Then when the engine warms up and the throttle valve opens all the way the vacuum suddenly goes to 0 when the variable intake valve lift takes over.
The servomotor for the variable intake valve lift could be the problem, or maybe the throttle body, check both.
Old Mar 5, 2025 | 05:45 AM
capncam's Avatar
capncam
Thank you! I’ll check the TB as well.
Old Mar 1, 2026 | 02:52 PM
golferc's Avatar
golferc
Hi, I got same codes. Did you fix yours? Thanks.
Old Mar 2, 2026 | 07:20 AM
capncam's Avatar
capncam
Originally Posted by golferc;[url=tel:4708527
4708527[/url]]Hi, I got same codes. Did you fix yours? Thanks.
yes. I went to the junkyard and found same year same motor same transmission car and took the valvetronic servo motor off of it. I cleaned it up and changed the spark plugs and it runs great now. Just search junk yards and find one, cost me less than $100. Just try to find one that someone changed the oil on, seems they wear because of sludgy conditions.
Old Apr 2, 2026 | 06:21 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
my MAN !! I've been for the life of me wondering why the vacuum was so low on my n18..
​​​awesome explanation ! Thank you..
Old Apr 2, 2026 | 07:45 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Yup, this is also why a mechanical boost-vacuum gauge is still beneficial on the N18 motor. If ever you see vacuum on your gauge, (or lower boost) you know something is wrong.
dawsonpeterson
Nov 29, 2024 03:18 PM
Alexzannder
Dec 15, 2021 03:41 PM
Xjsf28
Oct 15, 2020 10:25 AM
hardkhor
Aug 30, 2020 04:31 PM
mscarano
Dec 9, 2018 05:05 AM
