r53 - steering wheel intermittently jerking to left while driving
Old Feb 24, 2025 | 07:19 AM
R53Benny's Avatar
R53Benny
Hi everyone!
We recently picked up an ‘02 R53 with 75k miles, and it’s been an absolute blast. It needs a bit of work, but since I’m mechanically inclined, I was excited to take it on as a project. Everything was going great—until recently.
Not long ago, we took it on a four-hour road trip, and out of nowhere, I started feeling a slight jerk to the left through the steering wheel. At first, I thought it was just the road, but it continued even on smooth surfaces. Once we got back home, I did some research and checked for anything loose. I inspected for wheel play (grabbing the wheel and moving it up/down/left/right), used a pry bar to check for any unusual movement in the bushings, and generally looked for anything out of place. I did notice some play in the steering rack, specifically when replicating that same jerking motion.
So, I ordered a new steering rack, dropped the subframe, and replaced it. While the subframe was off, I decided to clean it up since it was covered in grime from a previously leaking valve cover gasket (which has since been replaced). I also replaced both passenger-side engine mounts (one was visibly broken) and the lower torque mount. Additionally, I flushed the power steering fluid. After putting everything back together, I took it for a drive—only to find that the issue was still there, unchanged.
According to the previous owner, the first owner used to autocross on weekends and made a few modifications, including:
  • Brembo brakes on all four wheels (massive ones up front)
  • A larger rear sway bar
  • Stiffer front LCABs
  • OZ rims with larger tires (205s)
  • An aftermarket intake
As far as I can tell, that’s everything that was done. The issue tends to show up a few minutes into driving and then persists at all speeds. It’s more pronounced during deceleration and always pulls to the left in a series of jerks. It’s rather snappy—without a firm grip on the wheel, it can actually pull you out of your lane.
Here’s what’s been diagnosed/replaced so far:
Replaced steering rack & flushed power steering fluid
New inner tie rods
Power steering pump runs normally, no unusual noises
LCABs were previously replaced (unsure how long ago, but they seem stiff)
All bolts torqued to spec (double-checked since I had the subframe off)
No strange noises while driving or turning hard in either direction
Swapped tires—issue still persists on the left
Replaced engine mounts (except the transmission mount)
Ran the car with the power steering pump unplugged—issue remained
Wheel bearings and CV axles seem fine (spin smoothly, no noise)
At this point, I’m stumped. Could it be sticky brakes? Am I missing something?
I appreciate any insights—thanks in advance!
R53Benny
14
Apr 15, 2025 06:20 PM
Mini_monster
Sep 14, 2019 12:25 PM
staudacher
Jun 5, 2018 05:40 AM
Mini_monster
Jun 28, 2014 05:46 AM
sripavan
Jun 17, 2012 08:24 AM
