R56 Oil filter housing Vemo
Old Feb 15, 2025 | 04:57 PM
2012_R60's Avatar
2012_R60
I’m in need of a new oil filter housing. Was looking at the ECS offerings and saw this Vemo option that is a lot cheaper than Purflex or Mini. Anyone has experience with these and how reliable they are?!
https://www.ecstuning.com/b-vemo-parts/oil-filter-housing-w-cover/v22-60-0055~vmo/
Thanks!
Old Feb 16, 2025 | 05:34 AM
mkov608's Avatar
mkov608
Yes, I've used a lot if Vemo products restoring many MINI coopers, and I've never had an issue. And if you get it from ESC it has a lifetime warranty. Curious though, why would you need a new oil filter housing. It's not a high failure part.
Old Feb 16, 2025 | 09:14 AM
2012_R60's Avatar
2012_R60
thanks for your recommendation!
​​​​​​​I’m leaking oil from it. I’ve already replaced the gaskets a few months ago. I’m thinking even if I screwed up the installation last time, if I’m going through all that work again might as well replace the whole thing for ~$120.
Old Feb 16, 2025 | 12:02 PM
habbyguy's Avatar
habbyguy
Seems to be just a machined chunk o' aluminum. Unless there's some reason to think it's been damaged, I can't imagine why it would require replacement...
Old Feb 16, 2025 | 02:37 PM
mkov608's Avatar
mkov608
I'd suggest you add some oil leak detection uv dye. It's available on Amazon. It will help you pinpoint the leak. There are also seals between the oil cooler and the manifold. That's where my leak was.
Seaswood
May 10, 2023 09:49 AM
cooper48
Apr 8, 2023 04:39 PM
vulkandino
Sep 19, 2018 05:59 PM
GregO
Jul 23, 2010 10:33 PM
meb
Dec 5, 2005 12:16 PM
