R56 original DiscBreak brand
Old Feb 15, 2025 | 02:35 PM
genik's Avatar
genik
original DiscBrake brand
Im over 150K with my R56S and its time to chage DiscBreaks. What DiscBreak brand is actually used by MINI?
Old Feb 15, 2025 | 04:04 PM
mkov608's Avatar
mkov608
Did you mean Brake? Check FCPEuro for pads. They typically list the OEM suppliers. But, you don't want them...high dust.
Old Feb 15, 2025 | 04:15 PM
genik's Avatar
genik
Im not referring to Mini Brake Pads, but Mini Brake Discs!
Old Feb 16, 2025 | 06:00 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Don't get convinced you need OEM brake discs. Go to RockAuto and select the least expensive solid rotors that have Gomet (or similar) environmental coating.
Old Feb 16, 2025 | 06:26 AM
genik's Avatar
genik
Im close to getting them, tell me more!
What’s Gomet for?
Old Feb 16, 2025 | 06:42 AM
mkov608's Avatar
mkov608
Geomet are coated rotors. Good idea if you live in high corrosive areas like Florida or where they salt the roads during the winter. Not needed in Arizona. I use RockAuto for all my brake pads & rotors. Powerstop offers a good product & they have a low dust pad option.
I also like the Dynamic Friction products.
Old Feb 16, 2025 | 06:44 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
The coating helps prevent rust. Something like this is all you need:
https://www.rockauto.com/en/moreinfo...t=1896&jsn=466
Just make sure you get the correct size.
Old Feb 16, 2025 | 07:25 AM
genik's Avatar
genik
Why not get the OEM brand that’s been used by Mini, but not purchase it from BMW?
Question is, what brand are the original break disks?
I don’t live in high corrosive area, I’m not so close to the sea.
Old Feb 16, 2025 | 09:24 AM
z168's Avatar
z168
OEM BMWs are Jurid, TRW or Textar. However regular steel discs are almost a commodity item.
On the higher end are Zimmermann & Brembo. Get whatever is in your budget and give more attention to the pads.
Old Feb 16, 2025 | 09:30 AM
genik's Avatar
genik
Im sorry my non native ENG are giving me a hard time to understand... can u please repeat in a more explanatory way?
Old Feb 16, 2025 | 12:05 PM
habbyguy's Avatar
habbyguy
Well, true if you never leave Arizona... ;-) I did an experiment and painted my front rotors with caliper paint (high temperature) and my rear rotors with clear coat, just to see if either would hold up. After a couple trips back to the frozen north, the clear coated rotors need some love again. I agree to get the coated rotors, even if you do paint them, because you can't really protect the inner areas, which will spew rust all over your nice clean calipers...
Old Feb 17, 2025 | 07:59 AM
Yep Jurid, TRW, Brembo dependent on what brake package. I Have the ECS V4 slotted on both my MINIs. I had them all. I have had EBC reds, akebono, hawk HPS. Depends on the driving and if you daily or track day.
I prefer the coated rotors as up here you get all kind of salt.
Old Feb 17, 2025 | 12:33 PM
genik's Avatar
genik
Ok thanks guys. Im not really using my R56S on the track, its mostly for daily use. Nor am i a mini tech to understand much about tech stuff. I gotta tell ya that im located in Europe, so im kinda lost regarding the brands. Like i said, i must replace my brake discs cause after 150K km they have become pretty thin.
As #njaremka said, i don't think i should be getting OEM brake discs either, although i kinda feel that its the safe way to go. On the other hand, i guess i shouldn't be spending so much money for OEM parts, not after 150K km (or should i?)... i have no clue what to go after... what would you say that my options are regarding DiskBreaks?
JayHammer
Nov 15, 2013 11:03 AM
mk1leg
Classic Mini Talk
Mar 6, 2012 07:00 PM
Dubaian
Off-Topic :: Autos
12
Jun 8, 2007 05:03 PM
insanecowboy
Jan 30, 2006 05:40 PM
