Hi guys i have a little problem, changing the alternator after car indicated red battery message of low voltage, alternator was checked to be not charging the battery so here we are, whilst doing that alternator upper bolt come out rather easily, however the lower bolt is getting blocked by the vehicles frame, pic attached, tried removing motor mounts to jack up the motor a little to give clearance for the bolt - won’t budge. Any help is appreciated. by the way car is mini countryman 2010 n47d16 frame and alternator closeup
