R50/53 Weird alternator fitting
Old Feb 10, 2025 | 05:25 PM
2out2sea's Avatar
2out2sea
I'm adding accessories to my new motor and ran into a weird issue. There is a gap between the block and the alternator at the top bolt (see pics). I have seen a couple of diagrams that show a spacer, but many that don't. I didn't notice a spacer when I took the alternator off of my old engine. Am I installing it wrong? Do I need to fabricate a spacer? Thanks for the help.
Old Feb 10, 2025 | 08:23 PM
2out2sea's Avatar
2out2sea
Added updated pic to show area of confusion.
Old Feb 10, 2025 | 10:55 PM
LukasH's Avatar
LukasH
I think you are putting the alternator on the position of the missing the AC compressor. From memory the AC is at the bottom and the alternator at the top. The bottom bolts of the alternator also go thru the top AC holes, if that makes sense.
Edit: just found an old picture I took during the supercharger service showing the setup
Edit2: looking at your photos again, the position of the alternator is correct but you are missing the AC and the supercharger to space things out.
Notice the AC below and the alternator above, sharing the same bolts+holes
Old Feb 11, 2025 | 04:12 AM
noodlesandsam's Avatar
noodlesandsam
The bottom pic is correct. Check some belt routing diagrams too.
Old Feb 11, 2025 | 08:34 AM
2out2sea's Avatar
2out2sea
Thanks guys. I was guessing I'd missed something. I'll recheck and try to find more pics. I didn't realize that the supercharger acted as the spacer. I was going to wait to reinstall the supercharger until after the engine was bolted in. But I thought I could get the rest of the accessories installed first. Thank you for the help. If anyone can link to a pic of the alternator mounted I'd be grateful.
Old Feb 11, 2025 | 09:54 AM
LukasH's Avatar
LukasH
I don't have one from the front but I do have one showing everything bolted together except for the alternator. One bolt into the supercharger (that clean circle) and two where the bolts are placed temporarily so I wouldn't forget. Also the main reason why I take so many pictures during disassembly.
Supercharger at the top, AC compressor at the bottom. Turns out they don't share bolts! Pretty sure the R50 does.
Old Feb 11, 2025 | 10:12 AM
2out2sea's Avatar
2out2sea
Ah... Perfect. Thank thank thank you. And you're right... You can't take too many pics. I didn't take enough obviously.
bre620
Oct 19, 2024 11:14 AM
imaslowdriver
Mar 25, 2023 01:00 AM
Ridered
Feb 15, 2019 05:34 AM
Delaware Mini Guy
Apr 25, 2011 02:13 PM
STLMINI
Classic Mini Talk
Jan 24, 2006 10:35 PM
