R50/53 JCW Air Filter Box Issue
Old Jan 23, 2025 | 09:58 AM
Tombstone's Avatar
Tombstone
Recently purchased a R53 JCW Mini and all 4- vacuum line rubber elbows are split , needing replacement . These control the flapper door operation and BMW/Mini sell these as 3-separate assemblies @ $ 55.00 each and wanted to know if anyone has a cheaper source for these elbows ? Thanks…
Old Jan 23, 2025 | 10:12 AM
JABowders's Avatar
JABowders
Veteran: Army
You should be able to get it as a single part ... #3 below
Old Jan 23, 2025 | 10:55 AM
Tombstone's Avatar
Tombstone
Thanks for the response on these parts but, the 3- assemblies would be $165.00 and I thought there was a more cost friendly alternative… If not I will have to bite the bullet
Old Jan 23, 2025 | 12:25 PM
ssoliman's Avatar
ssoliman
i think he is saying that all three come under one part number 13717558435
https://www.fcpeuro.com/Parts/?keywords=13717558435
verify here: realoem.com
Old Jan 23, 2025 | 12:39 PM
noodlesandsam's Avatar
noodlesandsam
Shop around - look on sites like Grainger. Any pics?
Old Jan 23, 2025 | 02:32 PM
Tombstone's Avatar
Tombstone
up.
Part numbers #15,16 & 17 have different part numbers….
Old Jan 23, 2025 | 04:31 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Unless you're a purist and want your vehicle to be as delivered, may I suggest that those parts are really extraneous. Most of us disconnect the vacuum line and perform the "Flapectomy", propping the flap in the open position
Old Jan 24, 2025 | 06:45 AM
Tombstone's Avatar
Tombstone
Thinking about plugging the vacuum supply line to JCW air filter top and de- flapping
Old Jan 24, 2025 | 06:56 AM
This is what it looks like, short hard vacuum line with two ends. https://www.realoem.com/bmw/enUS/sho...75#13717558378
All the vacuum lines:
https://www.ecstuning.com/Search/Sit...h/13717558435/
https://www.ecstuning.com/b-genuine-...e/13717558378/
https://www.ecstuning.com/Search/Sit...h/13717558379/
https://www.ecstuning.com/Search/Sit...h/13717557877/
Yes the system would open the flap under certain RPMs. Yep 18 and 19 are the sound plates.
On the old JCW tuning sound kit (Cooper) i have it has a little filter that goes towards the cabin so you can hear the engine all the time.
Old Jan 25, 2025 | 09:23 AM
Tombstone's Avatar
Tombstone
ECS Tuning is always helpful on these problems. Thanks again…
Old Jan 27, 2025 | 07:14 AM
Glad to help.
Old Jan 27, 2025 | 01:29 PM
Krunch2020's Avatar
Krunch2020
Glad to help.
Does having the flap open expose the filter to rain/ car wash water? It’s right under the grills behind the bonnet. Mine is still stock like most of the car. Inquiring minds…
Kurt
Old Jan 27, 2025 | 01:52 PM
JABowders's Avatar
JABowders
Veteran: Army
The Flap opens under Boost, but when you add the JCW Filter Box there is a hole that passes through the Driver Side Air Vent, this allows more cold air into the filter box, water intake isn't an issue as long as you don't try fording deep water e.g. over the hood where it can flood the air intake faster than the drain hole can drain it out) I haven't found a Car Wash that can dump enough water into that area fast enough to flood the air intake.
Old Jan 27, 2025 | 01:56 PM
+1 its on the back side and unless you go into high water you should be ok.
Old Jan 27, 2025 | 04:46 PM
NC TRACKRAT
Veteran: Navy
If you drive into water that high, you have far more problems than a wet air filter, namely, a hydro-locked engine, not to mention the threat of drowning!
Old Jan 29, 2025 | 09:44 AM
Tombstone's Avatar
Tombstone
Including all the electronics & sensors that don’t do well in a wet environment…
Old Feb 10, 2025 | 06:24 PM
Tombstone's Avatar
Tombstone
Figured out the JCW Airbox flapper door elbows , Dorman sells a 4-piece kit utilizing 1/8” x 5/32nd elbows (41431); which took 2-packs and also replaced the 1/8” hard plastic lines (47417). Total cost was 2-kits @ $8 each for elbows & 1-kit @ $9 each for tubing versus the OEM 3-lines @ $55 each from Mini/BMW …
shaolin29
Apr 20, 2012 05:17 PM
krackenthorpe
Jun 25, 2006 08:14 PM
mjwong6
Dec 13, 2004 12:03 PM
