R56 Steer arms fitting grease
Old Jan 2, 2025 | 08:03 AM
Seaswood's Avatar
Seaswood
There is recommended grease for steer arm before covering how much extra grease should be added?
when the cover is fit does the SS clamp close with force applied?
if I test that I may not get on but assuming force applied around clamp?
Old Jan 2, 2025 | 11:49 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
This is the stuff officially recommended by BMW:
https://www.ecstuning.com/b-genuine-...1/83238849305/
You might be able to find something comparable.
Old Jan 2, 2025 | 12:34 PM
Seaswood's Avatar
Seaswood
I have the grease from ECS how much should be applied before the cover is installed?
The interior SS strap looks like should close with pressure?
thnx
Old Jan 2, 2025 | 01:34 PM
This guys did this on a VW, seems since they share the same suppliers from ZF it should be the same.
Old Jan 3, 2025 | 06:21 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
You need a special tool to clamp those stainless retainers. I used zip ties, and 6 years later, they are still holding.
Old Jan 3, 2025 | 12:34 PM
Seaswood's Avatar
Seaswood
Thnx info just what I was looking for!
Old Jan 6, 2025 | 09:23 AM
Seaswood's Avatar
Seaswood
That vid from a VW seemed to miss that the rubber gaiter does not fit onto steer cover first one I got too hot trying to do in place with heat gun.
second one I heated slower whilst pulling it expanding the dimension of the bigger end to get to fit on the rack!
but was needed quite a bit of pulling & grease to get on the rack, go figure.
Old Jan 13, 2025 | 09:32 AM
Seaswood's Avatar
Seaswood
The rubber boot from Mini fit better did not need excessive stretching so on just warm up.
bahawton
Suspension
29
Sep 7, 2023 10:05 AM
TEDDYGP
Suspension
Sep 17, 2007 05:49 AM
k-huevo
Suspension
May 27, 2007 12:06 PM
sonichris
Suspension
Feb 6, 2007 11:13 AM
antsmini
Detailing 101
Apr 11, 2005 06:03 AM
