R56 Problem getting clip aligned
Old Dec 2, 2024 | 05:31 PM
hndle's Avatar
hndle
Can someone who has replaced the Coolant Temp Sensor with the angled connector share some wisdom on how to finesse the clip that holds the sensor on the Thermostat?
Every guide or video I have seen has the straight sensor, and most guides have you disconnecting the Oil Pressure Connection. My car does not have the configuration shown in those guides. It is like the below:
Mine has a vacuum connection, and it's a PITA to line up the clip. Certainly not the way portrayed below:
(copyright of the respective owner)
The connector is not the problem, as it swivels. I don't want to resort to removing the thermostat.
TIA
Old Dec 3, 2024 | 11:12 AM
hndle's Avatar
hndle
Problem solved
Further searches landed me on a thread where a member whose configuration matched mine, asked if they could remove the Vacuum Pump to get better access to the clip.
https://www.northamericanmotoring.co...ease-help.html
Voila!
Took about 10 minutes!
Thanks Kegworth, et al
orionwave1
Oct 13, 2025 05:36 PM
Kegworth
Jan 11, 2024 03:38 AM
nasomi
Mar 2, 2020 06:53 PM
jglover
Jun 16, 2018 04:51 PM
nimbus9
May 13, 2017 05:18 PM
