CAS permanent fix ???
Old Nov 17, 2024 | 05:55 AM
Farm91's Avatar
Farm91
2008 S, 6sp manual, no sunroof. CAS needs repair/ replace- short crank no start, brake lights on after key removal, chattering foot module relays. I’ve had the FRM out and apart - no water damage or signs of corrosion. CAS removed no signs of damage. Previous owner - burned up clutch let it set for six months, let AGM battery go dead. I bought the car, it ran, installed new clutch and water pump, brought AGM back to life. A few weeks later CAS issues started.
Has anyone come up with a solution to stop CAS module sun/ heat damage? How about extending the CAS wire harness and moving it? Or using a fan and temp sensor to cool it down when hot? Dyna-Mat or foil back insulation? Anyone out there repairing CAS not just cloning. Has anyone had the same trouble again after replacing or repairing it?
Old Nov 18, 2024 | 08:14 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Have you tested the brake light switch?
Old Nov 23, 2024 | 10:21 PM
memonava's Avatar
memonava
hi bro, i have the same problem with my 2011 cooper, u find a solution for this issue?
kodeyedwardjones
Dec 21, 2025 11:35 PM
Farm91
Nov 8, 2024 08:01 AM
Yngbld14
May 21, 2024 04:28 PM
Ryan-N57
Oct 25, 2022 05:14 PM
Tombstone
May 31, 2022 08:55 AM
