F55/F56 Coolant Flush Question: 2014 MCS B46 have 2-circuit cooling system?
Hi to all,
Im doing a coolant drain/fill on my 2014 MCS with B46 motor. I am reading different things where some claim the B46 is a 2-cicruit system with low-temp and high-temp reservior tanks? I know this is true for the larger B58 6 cylinder motors but I cant seem able to find evidence to confirm whether or not it applies to the B46 in the 2014+ Mini Cooper S. They are saying when there are the two systems, you need to bleed them both separately.
I want to be sure Im doing this right. Does anybody know if there are indeed 2 cooling circuits in this car?
Thank you!
Thank you!
Hi to all,
Thank you!
Thank you!
This technical training PDF on the B46 engine may or may not contain the answer -- not sure but worth a look.
(P.S. That PDF is *very* cool stuff in general.)
-=gRaY rAvEn=-
Jul 30, 2014 07:59 AM
er.
Jan 9, 2014 09:07 PM
