R56 R56 n14 Engine Specs
Old Nov 9, 2024 | 06:20 PM
robs_higher's Avatar
robs_higher
Hey all, how much hp is the n14 engine good for?
So far I've upgraded the exhaust, downpipe, intercooler, charge pipes, and got it tuned. I have a ton of fun driving it, but I'd like a little more. The next logical step would be to upgrade the turbo. The stock turbo gives instant torque in the low rpms and feels amazing, but it really begins to die off ~5k. However, I'm not sure how much of a beating the stock internals of this engine can take (the internet isn't really helping much so far). How much hp can this engine take before something breaks and what is the failing point?
I'm looking for around 280 hp, but I'm not sure how heavily it would affect reliability or how much life it's gonna take out of my car. Is there anyone who's done something similar to what I want that can speak from experience?
Old Nov 10, 2024 | 05:18 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I’ve heard 275-300 crank horsepower is about the limit, and anything higher would need uprated internals. 300hp would be a good candidate for meth injection, too. A bigger turbo will need a “stage 3” level tune. Who are you planning on going with for the tune? @Lou@Prototype-R has built a ~450hp N14 engine, and know these cars VERY well. Get in touch with him, and he can help with your goals.
Old Nov 10, 2024 | 02:41 PM
Raymo2u's Avatar
Raymo2u
I can tell you as an owner of a mini sitting just under 300hp, the weak point is the clutch. 2 Weeks after I got my retune for my new R300 turbo, the clutch is now slipping at WOT and I believe the flywheel is making noise on acceleration from a stop, also when putting the pedal down for WOT.
I plan on replacing my motor with a JCW N14 and trying a Clutchmaster FX250 or Giken GT setup....not quite sure yet as I hear positive and negative things for both and would like to not have to replace it again in a year or 2.
Old Nov 10, 2024 | 06:48 PM
robs_higher
Alright thanks, I've spoken with Lou before. He's great, only problem is that he wanted a grand for a tune, which is steep to say the least. Have you heard of any other good tuners? I'd prefer a dyno tune, but I've called/emailed dozens of places in Jersey and none of them would do a mini. I'd drive a couple hours to get it on a dyno if you know of anybody.
Old Nov 10, 2024 | 06:53 PM
robs_higher
Yeah I've heard that from other people as well, I figured a new clutch would be the next step after a turbo. Have you noticed a drastic change in reliability at that hp or is it still good?
Old Nov 10, 2024 | 08:58 PM
Raymo2u's Avatar
Raymo2u
I havent had any issues aside from the normal issues (waterpump, thermostat, and HPFP). The engine itself shouldnt have any problems as long as you are changing oil every 3k religiously and coils/plugs every year. Tire choice fixes most of the traction issues, personally I love the Nitto Neo Gens - but they suck in the rain...but they are cheap and grip well.
You do face alot of torque steer...but that gives the ride some excitement! At some point Ill get a LSD and see if that reduces it, Ive heard from many that it still happens but to a lesser degree.
Have you decided on what turbo you are getting? I went with RPMPower for my tune and turbo and its definitely a massive difference from stock. It pulls earlier than stock and lasts until redline, there are no dead spots anymore. As mentioned previously, you could get a meth setup and you wouldnt need to worry about building your engine for more HP.
If I had a second Mini I would like to test out the Mamba turbo and get a tune from Prototype-R and see the differences, though many people get the Airwerks turbo ($$$). I believe my choices were best for budget but still getting what I sought out for.
Old Nov 11, 2024 | 05:15 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Actually, for what you're getting from him, that cost is a bargain. I'd be willing to bet you'll spend similar to get a dyno tune. And whoever does your dyno tune will charge extra for each trip and tune adjustment. At Lou's cost, he will keep making adjustments until you're satisfied. And, do you really want to skip on the tune after spending all the monies on the car? The tune is what makes or breaks the effort.
Old Nov 11, 2024 | 12:07 PM
robs_higher
I'd simply prefer to get a local tune, although I'd definitely take Lou's offer over no tune at all. I just figured there's gotta be someone around here that'll do it. I know plenty of people who will tune other, more common cars for around $600 (that are a 10 minute drive away), so there's surely someone in the tristate area that'll dyno a mini.
Old Nov 11, 2024 | 12:14 PM
robs_higher
I was looking at the RPM Power turbo, it looked like the best balance for me. I was curious about the Mamba though, it looks nice but is suspiciously cheap. I know Detroit Tuned is a great company, so RPM Power seems like the move. My only question regarding them is the increased turbo inlet size. I have an S, not JCW, so it isn't 2 inches. On their website, it lists the JCW intake tube as a replacement. Is that one plug and play?? I feel like I'd definitely need to replace the rest of my charge pipes to match the diameter. What did you do?
Old Nov 11, 2024 | 01:07 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
If your car is an S model, and you have no plans on tearing the engine down and rebuilding, skip the RPM turbo, and just get an OEM JCW turbo or the Borg Warner Airwerks. No point spending the big bucks if you don't plan on building the engine.
https://www.ecstuning.com/b-borgwarn...space-0146~bw/
https://www.ecstuning.com/b-borgwarn...1657649496~bw/
Either of those options will save you ~$300 over that RPM turbo, which can go towards a tune.
Uli
May 29, 2024 05:15 PM
Bigfoot01
May 29, 2024 01:35 PM
CSCOTT1968
Mar 24, 2023 11:18 AM
5zero4
Mar 10, 2011 10:41 AM
