R50/53 Clutch issues, cant get shift into gear with engine running
Old Oct 28, 2024 | 01:36 PM
ssoliman's Avatar
ssoliman
Hi all, need some ideas, my son's R50 starting doing this last week. 2006 R50, manual trans.
With the engine running the car will not go in gear. With the engine off, no problems.
I've checked and bled the hydraulics, no leaks. The fluid was the color of coffee. All clear now.
When you engage the clutch pedal it makes a slight scraping noise. I'll attach a video. I'm not sure the sound comes through in the video.
Old Oct 28, 2024 | 01:41 PM
ssoliman's Avatar
ssoliman
Old Oct 29, 2024 | 02:50 AM
LukasH's Avatar
LukasH
I was thinking about this some more and one possibility is that the clutch fork is bent. Not sure if you can diagnose this without dropping the gearbox. The slave cylinder hole does give you a view on a small part of the fork
Old Oct 29, 2024 | 04:06 AM
Boostmaster's Avatar
Boostmaster
Mine did the same thing. It was an issue with the clutch assembly. For some reason the new LUK brand clutch had decided it would not engage. (It was a few months old and had worked). I swapped the clutch for a Valeo brand and no more issues. You can read more about it here. https://www.northamericanmotoring.co...-ideas-13.html
Issue stars around post #304 and goes on to #340
Old Oct 29, 2024 | 04:13 AM
ssoliman's Avatar
ssoliman
Appreciate you for the replies, sirs.
If anyone else had some experience with this I’d be interested to here about it
Old Oct 29, 2024 | 04:14 AM
ssoliman's Avatar
ssoliman
going to read through this
Old Oct 29, 2024 | 08:00 AM
ssoliman's Avatar
ssoliman
thats was very helpful. thank you. your situation sounds very much like mine. looks like im in for a new clutch...
Old Oct 29, 2024 | 09:10 AM
Boostmaster
Glad it was helpful!
Old Nov 4, 2024 | 08:07 AM
ssoliman's Avatar
ssoliman
here we are again my friends. waiting on parts
Old Nov 4, 2024 | 01:25 PM
LukasH's Avatar
LukasH
We've all been there, hopefully your new clutch will show up soon.
I'm hoping I don't have to take out the subframe anytime soon. Funny to see some many people have that type of transmission floor jack. Here in Europe it's either the Draper or Sealey brand, in the USA it always seem to be the HF or Pittsburgh.
Old Nov 4, 2024 | 02:50 PM
ssoliman's Avatar
ssoliman
ha! yes sir, HF trans jack, see it all over the forums.
have you had a chance to test your clutch yet?
here is the one that i ordered: https://www.fcpeuro.com/products/min...ooper-52001202
Old Nov 4, 2024 | 09:03 PM
LukasH's Avatar
LukasH
Not yet, waiting for a new slave cylinder so I can bleed the system. Fingers 🤞 my issue is that simple.
Old Nov 6, 2024 | 08:17 AM
Tombstone's Avatar
Tombstone
Definitely a clutch issue , because I recently purchased a JCW with this exact same problem and after tearing down discovered clutch & throwout bearing shot…
Old Nov 6, 2024 | 02:04 PM
ssoliman's Avatar
ssoliman
thank you for the reply, tombstone. I'm taking the opportunity to do some other needed maintenance while the subframe is out
Old Nov 26, 2024 | 09:35 AM
ssoliman's Avatar
ssoliman
no activity on the clutch replacement yet. i was able to do some work on the subframe while it is out.
-new control arm bushings
-new swaybar bushings
-new inner and outer ball joints
-new power steering hoses and reservoir
-new tie rods (not installed just yet)
Note on the control arm bushings, this (pic attached) assembly lube makes install a breeze. without it, nothing but curs words...
Old Nov 26, 2024 | 10:03 AM
LukasH's Avatar
LukasH
That subframe looks like new! Did you respray it or are you in a rust free state? New seen one that clean here in The Netherlands.
Old Nov 27, 2024 | 05:18 PM
ssoliman's Avatar
ssoliman
All I did was degreaser and a quick power wash. It was full of grim (power steering leaks)
we are in the south
Old Dec 16, 2024 | 12:08 PM
ssoliman's Avatar
ssoliman
I got the trans out. Looks like it had the stock clutch (Luk) in it. Looked ok at first, was not too worn, but then, on closer inspection, THIS. The pressure plate is broken! Everything else was in order. So mystery solved. I'm going to replace and put everything back together.
Old Dec 16, 2024 | 01:05 PM
LukasH's Avatar
LukasH
Woah that's quite bizar. Glad you found the issue and thanks for sharing. Never seen this before.
Old Dec 16, 2024 | 01:44 PM
ssoliman's Avatar
ssoliman
yes sir, if it were a bit to the right i would not have seen it. would've been hidden behind the outer shell of the pressure plate
placer
Oct 4, 2019 08:31 PM
john1234
Feb 28, 2015 05:40 PM
keating
Nov 5, 2011 02:50 PM
minu
Mar 14, 2010 10:24 AM
blitz64
25
Sep 29, 2005 07:07 AM
