R56 Cts intake vs nm
Old Oct 22, 2024 | 08:28 AM
mini-co-driver's Avatar
mini-co-driver
Cts intake vs nm
Gonna swap my stock(jcw) intake for one of these. I've seen videos that the cts intake is fine as long as you don't have a late r56 n18. My car is a 12' but I don't know the production date. The price is insane compared to the NM unit
Any experience with this would be a great help.
Also, as with the n18, do I need to order the pcv heater delete kit?
Old Oct 22, 2024 | 09:36 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Both of those intakes should come with the PCV heater resistors. If not, NM sells them as add-ons.
I think the biggest difference between the two intakes is the CTS uses the lower airbox, and the NM removes the full air box. The NM then includes a bracket to hold the OEM cold air pipe in place. Other than that, you're paying for big name with the NM. The NM looks better, in my opinion.
Old Oct 22, 2024 | 10:09 AM
Yep right here, little piggyback https://www.ecstuning.com/b-nm-engin...nm.658800~nme/
Old Oct 22, 2024 | 11:16 AM
mini-co-driver
you guys sell the intake as well?
I'm gonna do a catch can at the same time, but will amazon that piece
Old Oct 22, 2024 | 11:45 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
N18 engine shouldn't need a catch can.
Old Oct 22, 2024 | 11:54 AM
NM N18 intake R56 Cooper S : https://www.ecstuning.com/b-nm-engin...engine-intake/
Catch Can for NM N18 https://www.ecstuning.com/b-nm-engin...nm.498854~nme/
We have the ECS one but its universal for the catch can, i am running the design on my n14. +1 N18 does not seem to have the build up of the n14 engines. https://www.ecstuning.com/b-ecs-part...ine-emissions/
Old Oct 25, 2024 | 08:11 AM
mini-co-driver
I'm adding the catch can and heater delete to help some of my particular situation. I keep reading the cts isn't a great fit for the n18 and needs some finesse. My crankcase breather is alittle beat up so this will help two birds. The heater delete is to eliminate a bad connector I have, bypass it gets rid of that bad connector
Btw, I ordered from you yesterday
asysavanh
Aug 22, 2019 04:38 PM
BlackKat13
Feb 16, 2016 10:39 PM
MarioKart
May 20, 2014 10:44 AM
NewCooperFanatic
Sep 27, 2012 11:36 PM
