2009 R57 N12 brake vacuum pump leaks after new install
Old Oct 16, 2024 | 01:22 PM
amendola's Avatar
amendola
The old one was leaking, so I purchased a new one. I installed it and everything is fine for a while but after a few days the new one is also leaking. I did ensure that the ring stayed in place when I installed it. Is there a fix for this? Thicker O-ring? Something else? Help!
Jamie
Old Oct 16, 2024 | 02:44 PM
amendola's Avatar
amendola
I'm considering using RTV since the regular o-ring does not seem to do the job.
Old Oct 17, 2024 | 09:07 AM
Yes it should not leak. Did you get a new oring, I did mine and it was fine. Where did you get the vacuum pump from and where is it leaking.
Old Oct 17, 2024 | 09:12 AM
amendola's Avatar
amendola
On closer inspection, it appears that the leak is from the oil sensor next to it. I'm going to change the sensor, and hopefully that will stop the leak at that location.
Old Oct 17, 2024 | 10:49 AM
Yep, i bet it was something else, never seen one leak new.
redwhiteR562007
Apr 14, 2023 06:53 AM
jacknk
Oct 14, 2017 07:09 PM
Joe Beach
Mar 2, 2015 03:17 PM
satkinson2002
R55 :: Clubman Talk (2008+)
Feb 13, 2015 06:29 AM
TimG517
Nov 29, 2012 12:33 PM
