F55/F56 Warranty Extension (MINI USA): Evaporative Emission Control (EVAP) Purge Valve
Old Oct 16, 2024 | 06:54 AM
cjv2's Avatar
cjv2
Got a letter yesterday from MINI USA. Here it is verbatim. The "Evaporative Emission Control (EVAP) System Purge Valve" would seem to be the valve sitting atop the intake manifold, dead center, just below the plastic acoustic cover (aka the "pretty cover"). Easy to access, many of us have talked about it, some of us have had to replace it already.
There is a Reference in the letter: "MINI-ELW Purge Valve 15Y150M".
There are 2 additional pages (beyond what I have transcribed below) outlining how repair and/or reimbursement works.
In other discussions some have noted that the Purge Valve refers to or may refer to something else on different vehicles, or even a different part on different MINIs (prior generations I presume). This is fine and acknowledged. Unfortunately, the language around this valve and around EVAP valves and EVAP purge valves and vent valves gets pretty loose out there. So take the time to confirm that this letter refers to the part I have pointed out -- I have cross-checked but sorting it kind of is what it is.
If you find out it is something other than this part:
https://www.realoem.com/bmw/enUS/sho...diagId=13_1568
Please advise ASAP so that I can correct/update this post.
Hope this is useful.
October 2024
Effective as of the date above, the following Important Vehicle Limited Warranty Information applies to the MINI model with Vehicle Identification Number (VIN) [redacted].
Dear MINI Owner/Lessee:
MINI USA, a division of BMW of North America, LLC ("MINI USA") is extending the limited warranty for the:
  • Evaporative Emission Control (EVAP) System's Purge Valve on the above-referenced vehicle to:
  • 15 years/150,000 miles, whichever occurs first, as determined from your vehicle's original in-service date.
This component-specific extended limited warranty (ELW) applies to defects in materials and/or worksmanship. This coverage is subject to the same vehicle eligibility requirements and limitations that apply to the MINI New Passenger Car Limited Warranty.
If your vehicle is registered in a state that fully adopted the California emission regulation, the emission relevant coverage for your vehicle's purge valve is 15 years/150,000 miles.
This is not a notice of a Recall or Service Action. This is a notice of a "component-specific extended limited warranty."
Over time, the EVAP system's purge (vent) valve may devlop material and operational issues, this can cause hard starting, and the engine to run rough, especially while idling. Additionally, the Malfunction Indicator Lamp (MIL) may also illuminate.
If your vehicle is experiencing a situation like the one described above, please contact your authorized MINI dealer to schedule an appointment to have the issue with your vehicle diagnosed.
After the MINI dealer confirms that the scope of the component-specific extended limited warranty coverage corresponds and applies to a required vehicle repair, and your vehicle qualifies, the authorized MINI dealer will perform the covered purge valve repair work free of charge.
Repairs performed on ineligible vehicles, eligible vehicles operated and repaired outside the United States and Puerto Rico, the diagnosis and repair of issues and items that are outside the intended scope of this extended coverage, other unrelated issues, and/or that are due to outside influence are not covered by this extended limited warranty. This exclusion also applies to repairs that were performed using (including those repairs that result from using) non-genuine MINI parts and/or used MINI passenger car parts.
MINI NA will also reimburse qualifying customer-pay repairs performed prior to the release of this component-specific extended limited warranty, as described in this letter.
Our product's integrity is essential to MINI's success, and your trust. We are determined to exceed those expectations and hope this warranty extension will further enhance your ownership experience.
Sincerely,
MINI USA
Old Oct 16, 2024 | 07:58 PM
bluonyx's Avatar
bluonyx
Received the letter today for our F60 as well.
Love how it says, "This is not a notice of a Recall or Service Action. This is a notice of a "component-specific extended limited warranty."
Old Oct 17, 2024 | 07:57 AM
Thanks for the update, yep if it fails they replace. We have it in bremmen parts for a low price, if mine went i would just change it in the parking lot out here at ECS and save a trip to the dealer.
I changed my Genuine MINI thermostat on the R58 JCW here with bremmen parts even though it was under warranty extension, they could not even get me a loaner for like 2 weeks.
If its a recall they change it before it fails which is much better.
Old Oct 17, 2024 | 03:18 PM
cjv2's Avatar
cjv2
I feel about the same way. I spent under $30 to get a replacement part (manufactured by Bosch, which makes the Genuine BMW/MINI part as well). At that price it's a DIY well worth it for me without dealer/shop drama of any kind.
Old Oct 18, 2024 | 03:51 AM
lonewolf170's Avatar
lonewolf170
Just got the letter as well. 130k 2017f55s. Just popped a p0456 evap system leak detected code. Was wondering if it could be the purge valve, I'd rather not go to dealer if could avoid since don't want the diagnostic fee if it's not the "recall" part.
Old Oct 18, 2024 | 06:28 AM
Yea, if you lived down the road from the dealer, (most owners don't as their is only 1 dealer per 2 million people large city) then you are fine. We are over a hour each way to the dealer here and I don't go their unless I have to.
Also we have lifetime replacement now for about a year now, so if it goes bad again .. i can get another one... where the dealer will be like lets look at it. If its past the extended warranty it does not matter anyway ECS warranty will beat anything the dealer will do.
Old Oct 18, 2024 | 08:47 AM
lonewolf170
Do you have a part number? The ECS website isn't pulling stuff matching car. (I also could be checking the wrong name).
Old Oct 18, 2024 | 09:12 AM
We have this one: https://www.ecstuning.com/Search/Sit...h/13907621174/ and this : https://www.ecstuning.com/Search/Sit...h/13907614013/
You have to match up the part number with your old one. Their are a couple different designs. Most common is the ~1174
Old Oct 18, 2024 | 03:09 PM
cjv2's Avatar
cjv2
If your 2017 F55S is US spec, you have a B46 engine (not a B48 or B46C/B48C -- important!) and the part number is 13907621174.
Recommend you look your car up on realoem.com. Once you have specified your vehicle (including production month/year), the part can be found in the "Fuel Tank Breather Valve" diagram, which you can drill down to from "Fuel Injection System" (which you get to by drilling down from "Fuel Preparation System").
Old Feb 5, 2025 | 11:35 AM
rosh's Avatar
rosh
Does someone have the rest of the letter with the info on how to make a claim. We had to do this repair a couple of years ago, and want to see if we can get a refund. it took a while to track down the paper work and now we have misplaced the letter.
Old Apr 30, 2026 | 01:48 PM
Eddie07S's Avatar
Eddie07S
Also includes F60
Resurrecting an old thread…
I just received a letter from MINI/BMW stating that there is an extended warranty on the F5X F60 B36 B46 EVAP PURGE (VENT) VALVE and thought that others in the MINI community should know about it.
This appears to go back to something put out by MINI in 2024 and is posted on the nthsa.gov web (https://static.nhtsa.gov/odi/tsbs/20...09006-0001.pdf). That publication says it applies to 2017 B36 and B46 MINIs. However, I just received a letter for my 2023 B46 Countryman, so it appears that this is an issue a number of model years.
The warranty is limited to the F5X F60 B36 B46 EVAP PURGE (VENT) VALVE and covers it for 15 years or 150,000 miles, which ever comes first. There is also a section for reimbursement for repairs you might have paid for.
MiniDad08
May 11, 2022 04:35 PM
millerb7
Aug 21, 2013 03:32 PM
derphred
Mar 6, 2007 01:38 PM
