R56 No Boost
Old Sep 17, 2024 | 09:49 AM
Wiley_Oompa's Avatar
Wiley_Oompa
No Boost
Hey All. I have a no boost issue with my 2010 JCW R56. I have smoke checked the entire system and everything is tight. I have replaced my DV and my Wastegate Boost Solenoid. I still do not have any boost. I am looking for other things I need to check that could be the cause of no boost. My turbo spins freely and does go up to 4psi at WOT. Normal driving the boost sits at -3 to -11PSI. There are no codes and aside from not having any boost, the car drives perfectly. I am at a complete loss, thinking it could be my wastegate?? Any advice is hugely appreciated.
Thanx!!
Old Sep 17, 2024 | 01:02 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Maybe this will help.
Old Sep 17, 2024 | 03:01 PM
Wiley_Oompa
I appreciate you posting those, unfortunately I’ve been through all those checks. I even used little zip ties to secure my vacuum lines. I replaced the vacuum solenoid and checked the tank for leaks. The only thing I haven’t replaced is the actual vacuum lines.
I’m worried that it’s the wastegate..
Old Sep 17, 2024 | 07:19 PM
Maybe, maybe not
Community Builder
Does this help?
Old Sep 24, 2024 | 10:15 AM
Wiley_Oompa
I suppose if I have the turbo completely off the car these are helpful. I need to figure out how to evaluate the turbo and wastegate with it on the car. I really do not want to tear the entire front off the car just to test my turbo if I can avoid it.
tai842000
Sep 7, 2009 12:46 PM
thlaxx
May 12, 2007 06:49 PM
willy69
Feb 9, 2006 07:19 AM
Super_MINI
Mar 1, 2004 01:41 PM
