Headlight connector and wiring
Old Sep 6, 2024 | 03:23 PM
MiniMonkey08's Avatar
MiniMonkey08
Hi all
Feel like I'm going a bit mad here...
Was trying to work out which wire colour I need to tap into at the headlight (non-xenon) to switch the relay for spot lights I've added - so I want the high beam wire (UK)
In the process I've got rather confused...
​​​​​When I put a multimeter between either of the larger wires and ground (body), I have 12v all the time, even when key out. But the lights aren't on, and there's no voltage on the actual bulb connector.
But light only comes on when switched on, all works as expected
​​​​​​What am I doing , how is this possible
Switches or relays or anything in the headlight unit itself?
Am I making sense ?!
Old Sep 8, 2024 | 11:34 AM
mrbean's Avatar
mrbean
None of that make any sense.
Where exactly are you taking the measurement? On the plug that connects to the back of the headlight housing?
scubasteve98312
Classic Mini Talk
Jul 23, 2019 02:40 PM
sfoanna
Oct 5, 2008 12:15 PM
camelpilot
Electrical
14
May 1, 2006 08:20 AM
sharkee
Nov 20, 2003 04:07 PM
