R56 Turbosmart wastegate question
Old Sep 4, 2024 | 10:58 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
So should I run this optional positive pressure assistance valve on my turbosmart wastegate..reason I ask is I have a 25psi tune but with oem wastegate I can only briefly achieve 23psi and holds at 19-20.
so since I'm targeting 25 psi should I run this assistance port ? If I DO need to run this port , what vacuum/boost source do i tap into ? Would my dedicated boost gauge line work that comes out my aftermarket intake manifold or do i not need to run the assistance port ???
Old Sep 5, 2024 | 03:58 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Interesting… What do they mean by “positive pressure that the ECU controls”? Sounds like it should be connected to a boost source with a solenoid valve… I don’t think our cars have that. Do you have that wastegate actuator installed? How does it work for you otherwise?
Old Sep 6, 2024 | 08:15 AM
MiniManAdam
Community Builder
have not installed it yet... trying to find full / correct install guide because it's VERY UNCLEAR on how to setup the ports.
Am i running enough boost inorder to run the extra port ?where and what do i run that source off of if I even need to ?
im going to email turbosmart and if they cant give me an answer im sending this **** back..
Old Sep 6, 2024 | 09:58 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
This comment is posted in the FAQ section:
What is twin port control?
The Turbosmart vIWG Vacuum Actuator series has been engineered with a second chamber on the other side of the diaphragm which means you can boost assist. This will require a more advanced strategy and setup; however, directly or via a solenoid, plumbing positive pressure from the inlet manifold or turbocharger will allow a custom, much wider tuning window. What size is the reference fitting? The swivel banjo and fitting in the top cap is a -3AN, and the lower (optional) positive Pressure Assistance Port for Boost-Assist is 1/16NPT.
They make it sound like you can plumb direct from the intake manifold. I'd be curious to see how that works...
Old Mar 25, 2025 | 01:49 AM
ARD'sDIY's Avatar
ARD'sDIY
@MiniManAdam
Sorry if I bring this (nearly ) year-old post from the graveyard.
Any update on this project? I think it is very interesting.
PS: Are you running this on stock K03 turbo or else?
Old Jun 9, 2025 | 12:04 PM
pkgmSu2000's Avatar
pkgmSu2000
Is anyone else running this with the JCW N14/18 turbo? Detroit Tuned told me this is both wastegate upgrade and diverter valve upgrade. Doesn’t make sense to me eh?
TURBOSMART WASTEGATE ACTUATOR (VIWG) FOR MINI – 6INHG
https://www.detroittuned.com/turbosm...ch_query=Waste
Old Jun 9, 2025 | 02:41 PM
Coz3z3's Avatar
Coz3z3
I was told by my tuner that this doesn't gain anything. It's just if anything happened to yours, it's a replacement as Borg Warner doesn't sell it separately. As for what Detroit Tuned said, yeah I think the meant to include the actual diverter valve in an additional link
Old Jun 9, 2025 | 03:07 PM
pkgmSu2000's Avatar
pkgmSu2000
appreicate the insight thank you. I’m going with Mario’s tune next month
dunphyj
Mar 7, 2010 08:38 AM
fernflex
Jul 26, 2008 06:33 AM
EDM
Jul 27, 2007 07:24 AM
nocivic
Apr 10, 2006 05:48 PM
LoryIII
Apr 20, 2004 05:32 PM
