Navigation & AudioAudio upgrades, bluetooth, and navigation discussions surrounding the Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs.
I purchased my Auto 2012 R56 Hatchback a couple years ago for $1000 not running. The previous owner took the car to our local dealership and was told that he needed a new engine because of a burnt exhaust valve on Cylinder 2. I was able to confirm the burnt exhaust valve after removing the head. I never had any intentions of rebuilding the engine and was able to sell the engine/transmission for $500. This mini was bought to Kswap a K24 into it. I'm nearly complete with the install, but am waiting for my header before buttoning everything up because the headers need to be installed with the engine out. I had previously received my headers about a year ago from STS designs, but they built it wrong and interfered with a couple areas on the subframe and chassis. I sent the header back and they confirmed it was incorrectly built after putting it on their jig. I don't know how that happens, but whatever. The owner said he's building me a new one and i've been waiting about 6 months already. Anyhow, while waiting for the header, I figured I could start installing the audio portion of my build.
Hybrid Audio U3 speaker with Laser Cut Bracket. If anyone needs a bracket for their midrange speaker, I can make some for you.
Hybrid Audio U3 and 6.5" speaker installed in door
JBL DSP 4086 amplifier installed in the factory HK amp location. OEM connector cut off and used my own connectors to button everything up. I used the OEM power/ground wires and only needed to run the RCA wires from the headunit and a new set of wires to the A-pillars for the tweeters. Used all of the factory wiring for all of the speakers.
Total cost for everything was less than $1000 and it sounds a million times better than the OEM HK system. The frequency response of the system is phenomenal with a nice focused soundstage right in the center of the dash. I needed very minimal EQ to achieve the results below:
Do you have HK stereo audio?
Curious how this DSP would work with the OE speakers?
I think this is the 2nd time ive seen this JBL referenced as an HK alternative.
How hard would you guess this install would be for an AV amateur?
Yes, I had the HK system. The OE speakers in the HK system isn't bad at all and should work well with the JBL DSP/Amp. I've done many installs with the JBL DSP 4086 and recommend it as a budget DSP/Amp combo all the time. It is a very capable device as long as you know how to properly tune a dsp and you have the right hardware to tune it. If you're an amateur, you should be able to install this system without any issue. The problem will be properly tuning it. If you don't have the knowledge and tools, you should have a professional tune it. If you use the exact same speakers and headunit as me, I can send you my tune to upload.
Its a really good value and a lot of times you can find it on sale for a low as $299. I bought several when the price went down to $249 a couple years back and have been installing them into my beater cars and friends cars. Never had an issue.
Way cool and great post ! Got me thinking of doing an active speaker set up on my HK R57. A quick question - you mention that you used the OEM power/ground wires - what is the gauge of the power wire. I believe 8 gauge is recommended from the JBL - and a few guys had issues of over heating when using to small of a gauge. What area of the country are you in SS ? NC area by any chance That is where my Mini's are he he
Jamador - for DSP ( although I have no experience with his brand ) will be night and day on the amp after tuning! I personally would not be happy untuned - but again, that is comparing before and after. I did not have an after - I might be happy LOL
The OEM power and ground wires are 10ga (I think). Normally I would use 8ga for this amp, but since this was there, I used it. I haven't noticed anything out of the ordinary when using this and i've been playing the stereo using pink noise to tune it for hours at a time. The amp normally gets pretty hot and this I assume is normal operation because all of the JBL DSP4086 amps that I installed get hot like this. I'm in Hawaii so pretty much on the other side of the country from you.
Great that OEM power and ground wires seem to support. Plus saving some pain on the wiring - is this fused already ? Fusebox ? I had a hertz amp that ran hot - and warped the covering I made for it. I assume there is enough breathing/air in the OEM place ?
Very cool on Hawaii ! I actually reside in Southwest FL - so we are about as far apart you can get and still be in the US. If you ever want to observe Atlantic waters - drop on by.
