R50/53 R53 Facelift Car w/ Pre-Facelift Transmission
Old Jul 27, 2024 | 03:23 PM
Chucho Shoots's Avatar
Chucho Shoots
Hi Guys!
Recently I had to get a new transmission in my car, and I had a spare R53 Pre-Facelift Trans, so I had it installed.
Does this have any repercussions in terms of the car preforming strangely?
Thanks again!
Old Jul 28, 2024 | 05:57 AM
LukasH's Avatar
LukasH
I believe the only difference is the ratio of the 6th gear. Depending on the factory option a limited slip differential (lsd) could also be in your gearbox or not. If it has a label BKL, its has a lsd.
Wondering why you ask, are you having issues?
Old Jul 29, 2024 | 11:30 AM
Here2Go's Avatar
Here2Go
NAM Community Team
I had my 6spd manual Getrag replaced after a gear fork failure w/same pre-facelift transmission on my 04 R53.
I was told by the mechanic that I should've/could have replaced the pre-facelift gearbox with a facelift. His reason being that the later 1st gen facelift manual 6spd Getrags have a longer 6th gear ratio that cruises at top speed at lower rpms.
From what I have read/understand; the 1st gen pre-facelifts have shorter/quicker lower gears that are great launching the car off the line (1st-3rd) but will twist the engine higher (@3,000) rpms while cruising in 6th gear @85mph vs later 6spd manual Getrags (?)
Seems to be true in my 04 R53 by comparison to an 06 R53 I test drove.
I hope someone with more technical knowledge will respond to confirm or dispel my understanding.
Old Jul 29, 2024 | 05:00 PM
deepgrey's Avatar
deepgrey
Here are the overall ratios and max speeds per gear and tire size as pulled from an old faq from another site. I don't recall ever hearing about an electronic limiter in the R53, so I assume the speeds listed in sixth are drag limited (but don't quote me on that).
And to answer your question, the facelift cars all have shorter ratios in every gear... except fourth gear and reverse (14.105 vs 14.065) in the R50. Also, the One and the Diesel have different ratios from the normal R50.
It's not particularly relevant to this discussion, but I might as well also add the R50 ratios.
I've already gone overboard, so might as well continue to overdo it. Here's the One.
And the Diesel.
Last edited by deepgrey; Jul 29, 2024 at 11:02 PM. Reason: Actually answer the question directly.
Old Jul 29, 2024 | 09:36 PM
LukasH's Avatar
LukasH
Whoa this is great stuff!
Thanks for sharing the Cooper and One as well@deepgrey
Old Jul 30, 2024 | 06:24 AM
mrbean's Avatar
mrbean
The opposite is true if you look at the ratios deepgrey posted. Quick refresher: a larger overall ratio number means higher RPM for a particular vehicle speed and a smaller overall ratio number means a lower RPM for a particular vehicle speed.
(With that information, we can see the "tire fitment speed" numbers don't make any sense, but that's another discussion.)
PFL have "taller" gears (smaller ratio #s) overall. So there's lower RPM per mph for each gear compared to face lifted R53s.
Old Jul 30, 2024 | 06:52 AM
Here2Go's Avatar
Here2Go
NAM Community Team
Ah- Yes, with regards to both posted comments/correction above.
Clearly I misunderstood/inverted what I had read, told and my test drive comparison.
I have to admit I was probably a little bias (sentimental) towards my PF '04 and later '06 during the test drive.
Thank you for the great feedback,confirmation,clarification and supporting data!
Old Jul 30, 2024 | 02:55 PM
deepgrey's Avatar
deepgrey
@LukasH , you're welcome. I figured I would go ahead and post it since I don't know if it exists anywhere easily accessible other than archive.org.
@mrbean , what seems odd to you about the tire fitment speed? I didn't make those tables, but I get almost exactly the same numbers for the facelift R53 as that table shows, both for mph and kph.
Quick, lazy Matlab code below.
%% Cooper S
gear_ratios_post = [12.789 7.793 5.651 4.615 3.828 3.126];
tires = [195*.55*2 + 16*25.4, 205*.45*2 + 17*25.4];
rpm = 6750;
speed_kph = repmat(1./gear_ratios_post,length(tires),1).*rpm.*repmat(tir es',1,length(1./gear_ratios_post))*pi/1e6*60;
speed_mph = round(speed_kph*.62137119,1)
speed_kph = round(speed_kph,1)
Old Jul 30, 2024 | 04:24 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
cruise control probably wont work, but can be fixed in tune or opt for a facelift ecu with jcw tune (immobilizer bypass) (easier route)
Old Jul 31, 2024 | 05:53 AM
mrbean's Avatar
mrbean
@deepgrey I get almost the same numbers except for 6th gear (both pre and post facelift trannys) 264.6 kph and 252.7 kph,respectively.
Old Jul 31, 2024 | 06:14 AM
deepgrey's Avatar
deepgrey
Yes. I previously noted terminal velocity in the comment where I posted the tables. Whoever made them used what I assume is a quoted top speed since a stock R53 is incapable of running to redline in sixth.
Old Aug 1, 2024 | 12:41 PM
spz1's Avatar
spz1
Not to hijack, but where do you find the BKL label? on the diff?
Old Aug 1, 2024 | 01:09 PM
LukasH's Avatar
LukasH
No its actually on the outside of the gearbox on a sticker. There are quite a lot of codes for the different models. (Getrag/Midlands, 5/6 speed, lsd, facelift or not)
This is a BFA Getrag gearbox from a 2006 Mini One. The M is for manual, A will obviously be an automatic.
Old Aug 13, 2025 | 05:21 PM
Chucho Shoots
Sorry to Necrobump LOL,
I can confirm that the PF Trans works in Facelift cars, and it works really good.
With a Tune (197 WHP/176TQ, stock injectors and 17% Reduction, DDM Sealed Intake, and MSD) I can quickly speed up from 60-90 MPH with ease. I have a spare head from a PF engine, and I am going to do some research to see if I can fit a PF head on a Facelift Block, and if so, will be going a Big Valve head with a big cam, and 550cc injectors. Aiming to get to 275 WHP.
I actually went further with installing a Coolerworx Shifter, and was able to utilize the facelift cables on the PF trans, and everything bunches up perfectly. I do not get any DME faults, or bugs according to INPA either.
I'll link some photos of the car for your viewing
Old Aug 14, 2025 | 10:15 AM
ssoliman's Avatar
ssoliman
looks great!
polizei
How to
37
Apr 16, 2026 07:17 AM
RandyBMC
How to
112
Feb 8, 2020 11:13 AM
abuzavi
36
Jun 30, 2008 04:58 AM
imortalsin84
Feb 5, 2008 11:40 AM
