CV joint, wheel bearing, brake rotor, something loose. Time for a visual inspection.
I'll put it up on the QJ and do a visual this weekend. First thing I'll check is the wheel bearing doesn't sound like it, but you never know. Did change the brakes a couple months back so I'll check that, and tranny was swapped maybe 8 months ago. I didn't do the swap, but when it was done a new axle had to be install, can't remember which side though.
I see on the forums a few folks having the same issue, but never reporting back the solution. I'll post back once I figure it out. Thanks for the suggestions.
