2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Front Camber Adjustment (Currently Stock)
Old Jul 6, 2024 | 07:00 AM
brindan's Avatar
brindan
As I understand it, there is no built in camber adjustment on the F60s. My suspension is totally stock, and the front right tire wears unevenly on the outside 1.5” or so. I’m wanting to adjust the camber slightly to the negative to correct this. Is there a camber plate that works with the rest of the stock system? Do I definitely just have a bent arm or something? I’ve not hit anything, but someone else owned it a year before I did so it’s possible.
Appreciate any guidance you have! Thanks.
Old Jul 8, 2024 | 01:37 PM
Kmac has them.
https://www.ecstuning.com/Mini-2019-...n/Camber_Kits/
I would have it looked at first to see if anything is bent or damaged and then go from there at an alignment shop.
Old Jul 9, 2024 | 03:59 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Have you had the rest of the alignment checked? You might have a “toe out” situation on that corner….
Purie
Suspension
Jul 31, 2012 08:23 PM
succubus
Suspension
Sep 14, 2007 12:51 PM
fozworth
Suspension
26
Mar 1, 2007 06:44 AM
minihune
SCCA Solo and ProSolo
14
Jul 18, 2004 06:09 PM
