R58 Lights/Electrical
Old Jun 6, 2024 | 09:30 PM
Masseyred's Avatar
Masseyred
Lights/Electrical
Hi, All. Just bought a 2012 Mini Ciupe S and there are some light issues that are list below (understand this is the R56 page, but hoping to reach more readers as theres not much difference between models in this regard).The drivers footwell had bad water ingress (solved) and I replaced the corroded FRM module, had the info ported from the old frm to the new, and cleaned all the connectors but problems persist. Any hints as to the source of my problems? (Note - windows DO work)Interior dome - noMap lights - yesFloor lights - yesLower instrument panel - noFront l - no lights/turn at allFront r - turn & daytimes yes (no hi/lo ctrl)L & R fender turn lights - noRear tail l&r - noRear brake l&r - yesRear middle brake - noRear turn - l yes, r noFront fog - l yes, r noRear fog light - l yes, r noRear license light - yesReverse light - l yes, r no
Old Jun 7, 2024 | 04:29 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Start by checking the 4 Footwell fuses:
With the ignition key turned ON, do you measure battery voltage to body ground at both top test tabs for each of the 4 installed FRM fuses? If so, does battery voltage reach X14261 Footwell connector pins 1, 3, and 34 and X14260 Footwell connector pin 2?
RT/BL = red/blue wire
RT/SW = red/black wire
RT/VI = red/violet wire
RT/GE = red/yellow wire
Old Jun 7, 2024 | 05:37 PM
Maybe, maybe not
Community Builder
Information found on the fuse box cover suggests that 30A FRM fuses F4 and F8 are dedicated to the power windows, whereas 40A FRM fuses F52 and F53 are dedicated to the lights. This means that you can focus your multimeter tests on fuse F52, fuse F53, X14260 connector pin 2, and X14261 connector pin 34.
Old Jun 8, 2024 | 05:51 AM
Maybe, maybe not
Community Builder
https://www.northamericanmotoring.co...ml#post3877072
You also may find this^ post and other posts in this FRM dedicated thread helpful.
89325iturbo1
Feb 18, 2019 04:38 PM
MiniU4ia
F54 :: Clubman Talk (2015+)
Oct 23, 2018 05:53 PM
mikeesmini
Nov 30, 2013 09:45 AM
Braminator
Electrical
Jun 17, 2012 07:53 PM
biggripper
Mar 6, 2007 10:12 AM
